Hi guys,
maybe some remember my first project in 2008, where I designed and produced aluminium diffusers matching the VX's design. I also sold some here. What still annoyed me over all the years was that due to the wobbly aluminium, there was always a gap between the metal sheet and the rear clam. Also, the diffusers looked way too filigrane.
Since I am an industrial designer and now have connections to companies with 3D scanners and CNC mills, I developed a new diffuser during winter and spring. My main goal was to make a part that can be installed free of gaps and remains on the clam when you have to work in the engine bay from below. I took 3D scans of my Speedster and used the data for 3D modelling to achieve that perfect fit. I had a prototype milled and laminated it over by hand to test the fit and the new mountings on my car. As you can see on the last picture (the white-pink diffuser), it worked out great. Unfortunately, this prototype would have been way too expensive to be copied, since it is hand laminated due to its form. Also I found it then a bit too bulky and not OEM style looking. That's why I took all the proven data according shape and fit to redesign it as a one piece vacuum forming plastic part, which is of course a bit smaller and less aggressive, but way cheaper to make and looking like a factory part.
Since you can imagine that the form costs are quite high, please excuse that I can only show computer renderings and photoshop fakes at this point. Producing this diffuser only makes sense for at least 10 pieces, that's why I am currently looking if there are some people interestend in having one. Here are the pictures (click to enlarge):
The diffuser is made of 4-5mm ABS plastic, vacuum formed and then cut out with a 5-axis CNC mill. This should make the edges very precise (as long as this is necessary for a hand laminated rear clam with tolerance, of course). The plastic is black gloss, so no respray is necessary unless you want a different colour. Since it is replacing the original rear bottom cover, I also designed a new cover bridging the gap between the big cover under the engine and the diffuser. This cover is laser cut from 1,5mm aluminium, bent and powder coated. It will have ventilation cut outs in the final version to keep the engine bay cooler.
The set consists the diffuser, the new aluminium cover and the installation material and costs 490 Euro plus shipping (about 380 pounds). It might get even cheaper depending on how many are produced, since the costs vary on the amount. Shipping the parcel to the UK is about 20 pounds. So if you have questions or are interested in one of these, please feel free to post here or send me a message here or on Facebook (This topic can be found in the German Opel Speedster Club group).
Cheers from Austria, Marcus
P.S.: These are pictures from the first, bulky prototype and the installed new cover:
