Be Quick - 90% Finished Exige Project For Sale - �23,600
20 replies to this topic
#1 pat_t
pat_t
  • 7 posts
Posted 29 May 2016 - 04:25 PM
BE QUICK - car breaks to rolling chassis and goes to Europe next week if I don't get any offers complete!
[font="verdana, geneva;font-size:small;color:rgb(79,79,79);"]For sale as a 90% finished project. I have been having problems with a driveline issue and it has sapped the motivation from me. I'm certain the problem can be fixed, and its very possible that simply returning the whole flywheel & clutch assembly to standard F355 items would do the trick.[/font]
Tidy, low mileage (60k), 1999 base S1 Lotus Elise. Was CATD front clam damage but already previously repaired to a good standard when I bought the car. Obviously now there is almost nothing original bar the tub, windscreen and the wishbones (all bushes replaced).
Correctly registered as 3.5L V8 with correct Ferrari Engine number on DVLA V5. Currently insured with REIS, but SORN.
To have this car built for you by a motorsport garage would cost you into 6 figures, (and it still wouldn't have some of the technology/software strategy I have fitted - I design engines for an OEM). Over 4.5GB of folders, diagrams, CAD models, drawings, photographs and calculations and engine maps will come with the car to the new owner. I'd be willing to negotiate throwing in a laptop with the Cosworth CalTool software licence and cables required to map and talk to the ECU/dash. I'm also happy to offer some training on this, and generally be on hand on phone or email to support you to finish the car.
There's a modest spares package - mostly sensors, electrical connectors and engine components.
Also included I can transfer you ownership of ferotus.blogspot.com which gets around 1000 hits/month currently but might be useful if you wanted to race it/appeal for sponsors etc..
I haven't had a chance to weigh the complete car yet, but I will put it all back together and do so. I'm very confident it's under 800kg Wet.
Wrapped in HEXIS Gloss Orange professional automotive vinyl its an easy to clean finish that should hold up well to trackdays. I'll include the rest of the roll (loads left) for patching up stonechips etc.
Here's the current spec. 90% of the parts are brand new:
      [*]Ferrari F355 engine. 8x ITBS, trumpet intake system, 5valves per cyl, titanium con-rods, etc etc. Should be easily over 400bhp at the flywheel. Already 50% set-up and running well, just requires final mapping.
      [/list][*]
      [/list]
          [*]Ferrari F355 6-speed manual gearbox with LSD.
          [/list][*]
          [/list]
              [*]Billet steel lightweight flywheel.
              [/list][*]
              [/list]
                  [*]Paddle, sprung centre clutch.
                  [/list][*]
                  [/list]
                      [*]Billet harmonic pendulum balancer.
                      [/list][*]
                      [/list]
                          [*]Ferrari F355 gear-lever housing.
                          [/list][*]
                          [/list]
                              [*]William Hill Engineering aftermarket Ferrari shift gate.
                              [/list][*]
                              [/list]
                                  [*]Custom gear linkage.
                                  [/list][*]
                                  [/list]
                                      [*]2x Ferrari 360 fuel rails and 8x Ferrari 360 injectors.
                                      [/list][*]
                                      [/list]
                                          [*]Custom braided fuel lines used throughout.
                                          [/list][*]
                                          [/list]
                                              [*]Denso Coil on Plug conversion.
                                              [/list][*]
                                              [/list]
                                                  [*]Custom fully-TIG welded exhaust system.
                                                  [/list][*]
                                                  [/list]
                                                      [*]Absorbative single-can silencer.
                                                      [/list][*]
                                                      [/list]
                                                          [*]Straight-through mapping spec exhaust system with provision for twin-wideband lambda.
                                                          [/list][*]
                                                          [/list]
                                                              [*]Custom rear subframe modifications.
                                                              [/list][*]
                                                              [/list]
        [*]Welded in harness bar.
        [/list][*]
        [/list]
        [*]Custom Aluminium 38L Fuel tank with integral collector.
        [/list][*]
        [/list]
        [*]Custom bulkhead with heat protection.
        [/list][*]
        [/list]
        [*]Titanium fuel filler neck.
        [/list][*]
        [/list]
        [*]Sytec 255lph fuel pump. Adjustable billet FPR.
        [/list][*]
        [/list]
        [*]0-5bar fuel pressure transducer.
        [/list][*]
        [/list]
        [*]Custom Aluminium dry sump tank.
        [/list][*]
        [/list]
        [*]0-10bar oil pressure transducer.
        [/list][*]
        [/list]
        [*]Aston Martin OEM Fuel Pump Driver Module with closed-loop functionality (fuel pump speed control already 90% mapped)
        [/list][*]
        [/list]
        [*]Full custom Professional motorsport specification wiring loom.
        [/list][*]
        [/list]
        [*]Cosworth Pectel SQ6 ECU
        [/list][*]
        [/list]
        [*]Cosworth Omega D1 Digital Dash
        [/list][*]
        [/list]
        [*]All BOSCH: TPS, Wheel Speed sensors, Crank & Cam Sensors, Map sensor.
        [/list][*]
        [/list]
        [*]Kubota Denso Alternator. Custom Alternator pulley. Custom Alternator bracket.
        [/list][*]
        [/list]
        [*]2.25L plumbed in fire extinguisher system.
        [/list][*]
        [/list]
        [*]Pierburg E90 BMW 335i Electric Waterpump
        [/list][*]
        [/list]
        [*]56mm Core full aluminium radiator (with fan)
        [/list][*]
        [/list]
        [*]19row Mocal Oil Cooler (with fan)
        [/list][*]
        [/list]
        [*]EliseParts S2 “GT” rear uprights
        [/list][*]
        [/list]
        [*]EliseParts S2 “Race” front uprights
        [/list][*]
        [/list]
        [*]EliseParts hubcentric wheel spacers.
        [/list][*]
        [/list]
        [*]EliseParts full suspension bush kit.
        [/list][*]
        [/list]
        [*]EliseParts throttle linkage kit.
        [/list][*]
        [/list]
        [*]Nitron NTR shocks with helper springs all round.
        [/list][*]
        [/list]
        [*]Pilbeam lower rear wishbones.
        [/list][*]
        [/list]
        [*]Titan 2.25 quickrack.
        [/list][*]
        [/list]
        [*]Extended Wheel Stud conversion.
        [/list][*]
        [/list]
        [*]A number of F1-spec titanium fasteners used throughout the build where appropriate.
        [/list][*]
        [/list]
        [*]Stainless bodywork and external fasteners used throughout.
        [/list][*]
        [/list]
        [*]Japan Racing Volk TE37 rep 16” x9 rear wheels & 15”7.5 front.
        [/list][*]
        [/list]
        [*]Kumho V70A 245/45/R16 rear (new), 205/50/R15 front (lightly used)
        [/list][*]
        [/list]
        [*]Freno Carbon-Carbon brakes front and rear.
        [/list][*]
        [/list]
        [*]Custom VX220 Motorsport front clamshell.
        [/list][*]
        [/list]
        [*]Custom front splitter.
        [/list][*]
        [/list]
        [*]2x YUASA Motorcycle batteries. Anderson jump battery connectors.
        [/list][*]
        [/list]
        [*]Custom S1 Exige rear clamshell. Custom side skirts.
        [/list][*]
        [/list]
        [*]Lightened S1 Exige roof with motorsport scoop.
        [/list][*]
        [/list]
        [*]Custom fuel filler cap.
        [/list][*]
        [/list]
        [*]Custom LED brake, indicator and DRL lights, MSA rain light.
        [/list][*]
        [/list]
        [*]Motorcycle mirrors with integrated side indicators.
        [/list][*]
        [/list]
        [*]Custom clear Polycarbonate engine cover (very light)
        [/list][*]
        [/list]
        [*]Reverie XRC Pre-Preg carbon fibre driver’s seat.
        [/list][*]
        [/list]
        [*]Corbeau Carbon Kelvar passenger seat.
        [/list][*]
        [/list]
        [*]Custom dashtop with screen 4x electric fan demist.
        [/list][*]
        [/list]
        [*]FIA 4 point harnesses. Schroth harness pads.
        [/list][*]
        [/list]
        [*]Momo style suede steering wheel on quick release.
        [/list][*]
        [/list]
        [*]Custom interior switchgear and hydraulic handbrake.
        [/list][*]
        [/list]
        [*]APR Performance GTC-300 67” carbon rear wing. Custom wing mounts.
        [/list][*]
        [/list]
        [*]Custom rear wing endplates.
        [/list][*]
        [/list]
        [*]Custom rear diffuser.
        [/list][*]
        [/list]
        [*]Dave Mac Props “unbreakable” rear driveshafts with Porsche Inner CVs and standard S2 outer CVs.
        [/list][*]
        [/list]
        Contact Patrick on 07904 061484. Located in Leicestershire.
#2 The Batman
Posted 29 May 2016 - 06:17 PM
whats the last 10% to do
#3 pat_t
pat_t
  • 7 posts
Posted 29 May 2016 - 06:56 PM
Hi
  • Sort out the flywheel/transfer shaft  - probably about £2000 more in parts..
  • Finish mapping the engine (already about 25% done) - should be easily doable in one more day on the rolling road.
  • Extremely minor bits of bodywork - fitting catches etc.
That's it, :) then it's ready for shaking down on track.
Previous rolling road session:
Get in touch if you're seriously interested as i'm imminently accepting a deposit for just the rolling chassis otherwise!
regards,
Pat
#4 nicollow
nicollow
  • 3,801 posts
Posted 29 May 2016 - 08:18 PM
If I wasnt married, Id have this as my wife
#5 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 29 May 2016 - 08:43 PM
Time to sell the S1 then Joe :D
#6 The Batman
Posted 29 May 2016 - 08:46 PM
NEVER!!
#7 hughcam
hughcam
  • 730 posts
  • Interests:driving, motorcycling, snowboarding, v12 lawn mowers
Posted 29 May 2016 - 08:47 PM
Why do all the hard work then give up at the last hurdle?
#8 pat_t
pat_t
  • 7 posts
Posted 29 May 2016 - 08:51 PM
I'm just not enjoying it anymore, decided to cash out and buy something I can use straight away. This could make an incredible car one day for someone though, I've done the groundwork :) ...and as I've stated, the asking price is way less than you could build another for!
#9 MAXR
MAXR
  • 2,719 posts
Posted 30 May 2016 - 05:44 AM
If you like, I can put it up a link on a well known Ferrari forum for you. It will generate interest... I would have had this from you if it was fully finished & mapped.
#10 pat_t
pat_t
  • 7 posts
Posted 30 May 2016 - 06:05 AM
MAXR, thank you for that offer, please go ahead. If I end up splitting engine I may need to advertise on the ferrari sites.. If it was finished by now I probably wouldn't be selling and certainly not at this price. :) FYI it's insured agreed value (approved by underwriter) for £55K currently
#11 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 30 May 2016 - 06:45 AM
Could it be road legal? DG
#12 pat_t
pat_t
  • 7 posts
Posted 30 May 2016 - 07:15 AM
Could it get a daytime MOT currently at a friendly test station? Yes (what I was intending) Strictly speaking legal to the letter of law? No (hydraulic handbrake, no Cat. Lights are ok for daytime MOT though)
#13 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 30 May 2016 - 07:36 AM
Thanks Pat DG
#14 MAXR
MAXR
  • 2,719 posts
Posted 01 June 2016 - 04:47 AM
Does anyone know how to get hold of Pat? I've messaged him yesterday.
cheers
Max
#15 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 01 June 2016 - 05:47 AM
Hi max did you try his mobile number? Contact Patrick on 07904 061484. Located in Leicestershire DG
#16 MAXR
MAXR
  • 2,719 posts
Posted 01 June 2016 - 06:32 AM
He's emailed me now, thanks!
Max
#17 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 01 June 2016 - 07:28 AM
Could a moderator tidy the OPs opening post... as It is a mess of bullet points.
#18 pat_t
pat_t
  • 7 posts
Posted 19 June 2016 - 07:05 PM
Going to give this one more week before I resign myself to breaking it for parts :(
#19 pat_t
pat_t
  • 7 posts
Posted 01 July 2016 - 09:30 PM
[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.3333px;]SOLD [/color]
[color=rgb(0,0,0);font-family:verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif;font-size:13.3333px;]To a fellow petrolhead, local to me so I can't wait to see it finished and get a pax ride! :)[/color]
#20 Duncan VXR
Duncan VXR
  • 5,284 posts
Posted 02 July 2016 - 08:37 AM
Glad it has gone to someone to finish 👍 DG
