Hi,
I have for sale a brand new kit of Wiseco pistons for NA application or low boost SC.
£500 +delivery
Posted 11 June 2016 - 09:47 PM
Hi,
£500 +delivery
Posted 11 June 2016 - 10:26 PM
Posted 11 June 2016 - 10:36 PM
Posted 11 June 2016 - 11:46 PM
10:1 is standard CR on the Z22SE, isn't it?
Posted 12 June 2016 - 01:20 AM
yes.
Posted 12 June 2016 - 07:46 AM
these are best suited for a low mileage engine due to the standard 86mm bore.
Ideal for a stage 3 SC (300bhp) when matched with some steel rods.
Posted 12 June 2016 - 08:30 AM
Posted 17 June 2016 - 08:42 PM
New price: £450 delivered
Posted 17 June 2016 - 09:04 PM
What happens when it's high mileage?these are best suited for a low mileage engine due to the standard 86mm bore. Ideal for a stage 3 SC (300bhp) when matched with some steel rods.
Posted 17 June 2016 - 09:13 PM
You then need oversized bores. So these wouldn't suit any car over 5-6kWhat happens when it's high mileage?these are best suited for a low mileage engine due to the standard 86mm bore. Ideal for a stage 3 SC (300bhp) when matched with some steel rods.
Posted 17 June 2016 - 09:17 PM
Posted 17 June 2016 - 09:18 PM
[font="arial, helvetica, sans-serif;"]High mileage means wear so the bores might be out of tolerances and the [color=rgb(0,0,0);text-align:justify;]the correct "cross hatch" finish for the piston rings will be worn as well[/color][/font]
First you check bore size for any wear and if still within limit you can flexhone the bore to restore a cross hatch finish
Yes. Which means you need wider pistons than the standard 86.0mm that these are.
Posted 17 June 2016 - 09:29 PM
Posted 18 June 2016 - 08:05 AM
To dispute the above, the Z22SE has pressed in cast iron liners which means much straighter bore than cylinders bored directly into the block. This means you're much less likely to see bore polishing and there's a good possibility you can directly drop the pistons in without needing to re-bore. My 90k engine had perfect honing when it came out of the engine.
Worth a borescope if you're not certain
Posted 19 June 2016 - 07:07 PM
Posted 19 June 2016 - 07:18 PM
Posted 09 August 2016 - 06:35 PM
Up
