Boost Pressure On Supercharged Cars
Posted 10 July 2016 - 07:55 AM
Posted 10 July 2016 - 08:18 AM
Posted 10 July 2016 - 08:20 AM
I don't think it can be as my m62 did exactly the same. But at a much lower boost pressure.That'll be the restricive manifold
Posted 10 July 2016 - 08:23 AM
Surely that's the argument for a restrictive manifold. M62, lower boost (lower rotor sealing too) means pressures become balanced at a much lower point than with a tvs.I don't think it can be as my m62 did exactly the same. But at a much lower boost pressure.That'll be the restricive manifold
Edited by fezzasus, 10 July 2016 - 08:24 AM.
Posted 10 July 2016 - 08:27 AM
Posted 10 July 2016 - 08:36 AM
Posted 10 July 2016 - 11:50 AM
Remember it's a fixed displacement charger you have there, so the flat boost line is pretty normal on our SC conversions
If you boost rises sharper at the top end, then the head/cams/exhaust beging to cause you powerloss.
ps; boost is a measurement of restriction...
ps2; your 1.15bar max boost is very very good for the pulley size and powerlevel!!
Posted 10 July 2016 - 11:57 AM
This is a log of my 2.0 Harrop engine on the dyno with a 80mm pulley, stage 2 cams and 2,5" exhaust.
Same flat pressure curve but a bit higher than yours (MAP/boost pressure 227KPa=1.27bar) due the smaller displacement, cams and exhaust:
Edited by Exmantaa, 10 July 2016 - 11:58 AM.
Posted 10 July 2016 - 06:18 PM
Posted 10 July 2016 - 06:58 PM
Posted 10 July 2016 - 07:04 PM
Posted 10 July 2016 - 07:16 PM
im presuming that the bypass valve is what's causing the pressure to stablise. I may have a play around with it when I'm next on the Dyno
No, it's a fixed displacement pump...
Posted 10 July 2016 - 07:32 PM
Exactly so surely the higher the revs the higher the boost? if I find the time I'm going to take the laminovas out and do a run without them. I think this will answer a lot of questions for peopleNo, it's a fixed displacement pump...im presuming that the bypass valve is what's causing the pressure to stablise. I may have a play around with it when I'm next on the Dyno
Posted 10 July 2016 - 07:50 PM
The bypass valve should stay open at idle and low throttle application and stay closed under full throttle.
I have checked this action in the past, using a cheap security mini video camera, aimed at the bypass valve actuator. You will need lighting in the engine bay as well.
The efficiency of an Eaton type blower will also fall off as it reaches its designed upper rev limits. They will not keep pumping air, at the same rate relative to rpm, above their design limits.
Edited by 909, 10 July 2016 - 07:59 PM.
Posted 10 July 2016 - 08:05 PM
No.
The SC displacement is fixed to the crankshaf, so for simplicity; let's say for every crank revolution the SC makes 2 revolutions. (determined by pulley size)
In your engine that's 1.2litre engine displacement while the Harrop crams 2 x 1.32litre inside. That means the pressure in the manifold is raised by a factor 2.2. Whatever the rpm is...
The real boostpressure is a lot more complex with sc leak paths and thermal efficiency etc., but you get the point.
But doing a run without the laminova's will be an interesting test. Or fit a pressure gauge before the laminova's to see the pressure loss they create.
Edited by Exmantaa, 10 July 2016 - 08:06 PM.
Posted 10 July 2016 - 08:22 PM
Belt slip at higher rpm's is also a point to consider. It is quite suprising how tight a multi rib belt has to be to prevent slip on the supercharger pulley, especially on a smaller supercharger pulley.
I chased a low boost problem for quite some time, not on a VX220, before somebody else suggested checking belt slip.
Checking this on a dyno, using an optical rpm meter, could perhaps be possible.
Posted 10 July 2016 - 09:03 PM
Just ordered a fitting to go in my ZZP sandwhich plate pre laminovas, so when it's next on the Dyno I'll measure the pressure drop to give us a better idea what's going onNo. The SC displacement is fixed to the crankshaf, so for simplicity; let's say for every crank revolution the SC makes 2 revolutions. (determined by pulley size) In your engine that's 1.2litre engine displacement while the Harrop crams 2 x 1.32litre inside. That means the pressure in the manifold is raised by a factor 2.2. Whatever the rpm is... The real boostpressure is a lot more complex with sc leak paths and thermal efficiency etc., but you get the point.
Edited by 1cobrav8, 10 July 2016 - 09:03 PM.
Posted 10 July 2016 - 09:04 PM
Just ordered my 6pk belt as was still only on my 5pk when I Dyno testedBelt slip at higher rpm's is also a point to consider. It is quite suprising how tight a multi rib belt has to be to prevent slip on the supercharger pulley, especially on a smaller supercharger pulley. I chased a low boost problem for quite some time, not on a VX220, before somebody else suggested checking belt slip. Checking this on a dyno, using an optical rpm meter, could perhaps be possible.
Posted 10 July 2016 - 09:08 PM
Edited by CHILL Gone DUTCH, 10 July 2016 - 09:09 PM.
Posted 10 July 2016 - 09:23 PM
if the size of the belt is the same, then then pressure applied would be the same wouldn't it?
the 6pk belt would offer more surface area to grip to.
