Intercooler
Posted 04 August 2016 - 09:20 AM
Posted 04 August 2016 - 10:11 AM
Posted 04 August 2016 - 11:51 AM
Posted 04 August 2016 - 12:03 PM
not that I think having a bigger pressure drop is a good idea with a much longer intercooler and you still have the same amount of airflow through the air scoop , but if you must go bigger I/C, then Uwe Regelin who is a respected tuner in Germany vx-performance is better than UK offerings imho ;
http://www.regelin-p...mqv0cpqecqlpli4
this is used for his stage 2.5 map , [color=rgb(0,0,0);font-family:Arial, Verdana, Helvetica, sans-serif;]Stage 2.5 for Speedster Turbo: 261PS 451Nm[/color]
Posted 04 August 2016 - 12:45 PM
Posted 04 August 2016 - 12:49 PM
the problem with all of these is they do not come with a ram air shroud and seal to channel airflow and a negative pressure zone behind the exit.
Posted 04 August 2016 - 01:12 PM
Edited by tibby, 04 August 2016 - 01:14 PM.
Posted 04 August 2016 - 01:45 PM
Posted 04 August 2016 - 02:37 PM
Posted 04 August 2016 - 02:54 PM
I'll let you know Lee!
Posted 04 August 2016 - 03:29 PM
Posted 04 August 2016 - 03:40 PM
streetuse that is....You're doing a Z22SE turbo build?????? Thought a Z20LET build like you mailed me ??? Oem turbo intercoolers are fine for you're wanted power...
Posted 04 August 2016 - 03:45 PM
Yeah, too much effort to swap a Z20LET Just going the easy road
Posted 04 August 2016 - 03:46 PM
Posted 04 August 2016 - 03:49 PM
Have you been talking with Daan? :-)Yeah, too much effort to swap a Z20LET Just going the easy roadYou're doing a Z22SE turbo build?????? Thought a Z20LET build like you mailed me ??? Oem turbo intercoolers are fine for you're wanted power...
Posted 04 August 2016 - 03:56 PM
If Rob can get it to me before next Wednesday, I can bring it to Zandvoort on Thursday/Friday and pass it on to one of the Speedster guys, if you're not there.
Suspect Lee can do the same with his one, as he's going to be there too.
Posted 04 August 2016 - 04:19 PM
Should be able to do that Matt....thank you.
What do you think Timmy?
Posted 04 August 2016 - 04:38 PM
20 pound is not much! If the Intercooler is up for the job for the 260 - 290 HP range? Then please bring it to Zandvoort! I'll be there
Posted 04 August 2016 - 05:41 PM
Dbilas also use a tiny (audi) intercooler for it's 300hp Z22SE turbkit. (bottom picture)
The oem z20let intercooler is probably not much bigger than the Dbilas one...
I suggest u go for an uprated bigger intercooler when pushing the 290 hp range....
Edited by tibby, 04 August 2016 - 05:50 PM.
