Many of you will know the car and its history better than myself, I bought it from Mbes earlier this year rather than modifying the standard-ish VX220 I have for sale. I also have a track spec Mini that I occasionally use. I plan on selling all 3 and buying an Atom or another Exige S.
Spec as Follows:
Chassis 60k
Original engine rebuilt 5k ago
Original gearbox rebuilt with LSD added 1k ago
HPI clear
Engine
Custom MBR Stage 4+ Map
Stage 4 cool running plugs
Pro Alloy Rad
Pro Alloy Chargecooler
VXR Turbo charger
Turbosmart recirculating valve
80mm pipe work
VXR High Flow fuel Injectors
Apexi Universal Power Intake Filter & Flange 80mm
Z20LEH 80mm AMF
Wossner Forged Pistons with Engine rebuild
Wossner Uprated Lightweight Steel Rods and ARP Rod Bolt Kit
Balancer Shaft Removal Kit
Uprated Higher Flow Fuel Pump 255
Alloy High Flow Plenum
Forge Dual Piston Ram Dump Valve
Cam Breather pipe
Full `Chris Tullet` 3" exhaust system Front pipe, been de-cat
Drivetrain
Quaife LSD
Helix 4-paddle clutch
Lightened & Balanced flywheel
Gearbox Breather
Chasis/Wheels
Matthew Bentley Racing Ltd GEO
Uprated 1" Antiroll bar EP
GaZ nickels suspension spring rates front 425 rear 475
Team dynamics pro race 1.2 (16/
Yokohama ADVAN Neova AD08 Front / back
Polyurethane Engine Mounts
Braking
Pagid RS42 fronts, RS14 rears
Blue racing fluid
Blue racing brake fluid
HEL brake lines
Foglight removal front brake cooling kit
Interior
Custom leather side sills
Upgraded Leather lumber supports
Autogauge Turbo Boost Gauge
Alloy indicator stalks
Exterior
Jimsan diffuser
Carbon GT wing 10" wing mounts
Upgraded Front splitter
Splitter Tie Bars
Front louvers
Central locking
£15500.00
