Engine Manual For Turbo Vx
Posted 19 August 2016 - 09:13 PM
Posted 19 August 2016 - 10:41 PM
Posted 20 August 2016 - 06:35 AM
Thanks does any of the Haynes manuals loosely cover this engine, Zafira, Astra etc ???Not sure if anything in here will help: http://www.speedster...ates/index.html
Posted 20 August 2016 - 08:26 AM
Has anyone got a repair/rebuild manual for the 2l turbo, checked the ones on line but can't seem to get Specifics, around camshaft removal and timming
In my head, be specific about what details you need and maybe we can help, though I am not willing to write a whole book on how to strip and build the Z20LET.
Camshaft and timing is really easy, just look at what you have, put the cam lock tool in, then when you re-assemble make sure all cam wheel markings are the same (hint: use a camera before dis-assembly). Hand turn the crank 720 degrees prior to start up to check for fouling.
Edited by Nev, 20 August 2016 - 08:35 AM.
Posted 20 August 2016 - 10:45 AM
Ideally full head strip down, cam removal and valve stem seals ow and torque wrench settings also just handy too earn more about this engine.In my head, be specific about what details you need and maybe we can help, though I am not willing to write a whole book on how to strip and build the Z20LET. Camshaft and timing is really easy, just look at what you have, put the cam lock tool in, then when you re-assemble make sure all cam wheel markings are the same (hint: use a camera before dis-assembly). Hand turn the crank 720 degrees prior to start up to check for fouling.Has anyone got a repair/rebuild manual for the 2l turbo, checked the ones on line but can't seem to get Specifics, around camshaft removal and timming
Edited by Eliselee281275, 20 August 2016 - 10:47 AM.
Posted 20 August 2016 - 10:49 AM
Think the page is down but thanks anywayTry here: http://www.zlet.co.uk/techpage.htm
Posted 21 August 2016 - 06:16 PM
Read this for torque values: http://www.vx220.org...-torque-values/
Next time, try using the search function (or google) to help yourself.
Edited by Nev, 21 August 2016 - 06:26 PM.
