Rubber On Tat Keeps Falling Off.
23 replies to this topic
#1 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 August 2016 - 12:12 PM
Anyone know a good product to permanently stick this rubber to the TAT?
Posted Image20160822_124707 by Richard Fanders, on Flickr
The rubber goes around the edge of the diffuser, I need it because some of the paint has flicked the edge.
Posted Image20160822_124723 by Richard Fanders, on Flickr
#2 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 22 August 2016 - 12:19 PM
Glue
#3 muckyman
muckyman
  • 340 posts
  • Interests:Barmaids
Posted 22 August 2016 - 12:24 PM
lol, did you take it off again?
#4 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 22 August 2016 - 01:16 PM
you don't want your rubber falling off.
on a serious note I have some pretty stronk stuff that will make it never come of again if you want to pop into clacton
#5 Wolfstone
Wolfstone
  • 12,984 posts
Posted 22 August 2016 - 01:41 PM
Maybe try a different rubber trim? http://www.carbuilde...=grid&orderBy=0
#6 techieboy
Posted 22 August 2016 - 01:45 PM
:yeahthat: I used this version http://www.carbuilde...c-edge-trim-3mm It took a rubber mallet to get most of it on and it hasn't budged in about 6 years despite the diffuser being on and off dozens of times.
#7 jonnyboy
jonnyboy
    The hardtop guy
  • 8,288 posts
Posted 22 August 2016 - 02:31 PM
Run a bead of sikaflex down the U channel. Not a lot of stuff actually sticks to rubber.
#8 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 August 2016 - 03:50 PM
Thanks for your replies. I've been to the shop around the corner from me and found this stuff and I've called the powder coaters and got quoted £50 for a blast and repaint. If this doesn't work I will give up with the rubber and get it refinished, although it's in very good condition overall so I would rather keep my rubber on :)
Posted Image2016-08-22_04-47-19 by Richard Fanders, on Flickr
#9 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 August 2016 - 03:54 PM
Yeah I wasn't please with how it was fitted, it rattles but I think I know what I need to do to sort that also the rubber fell off on the way home. I found out what the metal bracket is for. You're supposed to put it above the clam at the back of the diffuser (between the clam and the exhaust heatshield) and screw the bolts into it. I already got one on mine but couldn't see it because it was dark, you need it for yours so I'll keep it to one side for you. You also need to buy this ideally as you were missing all your rear bolts:
http://www.ebay.co.u...H8AAOSwzgRW0eGO
Thanks for that, I may send you a message if I get stuck  :lol:
Edited by gaffer1986, 22 August 2016 - 03:55 PM.
#10 jonnyboy
jonnyboy
    The hardtop guy
  • 8,288 posts
Posted 22 August 2016 - 04:20 PM
Silicone wont stick to the rubber
#11 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 August 2016 - 04:32 PM
That's what I thought but this one says it does:
Posted Image2016-08-22_05-31-05 by Richard Fanders, on Flickr
#12 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 August 2016 - 05:12 PM
Thanks for those links, I wouldn't have known what to search for.
#13 gaffer1986
gaffer1986
  • 4,408 posts
Posted 04 September 2016 - 06:32 PM
This stuff has seemed to work very well so far, seems very stuck on.
#14 Nev
Posted 04 September 2016 - 08:00 PM
Why does it need the rubber in the first place ?
Edited by Nev, 04 September 2016 - 08:01 PM.
#15 gaffer1986
gaffer1986
  • 4,408 posts
Posted 04 September 2016 - 08:01 PM
Looks good, also some of the paint has chipped off ;)
#16 phippsy
phippsy
  • 472 posts
Posted 04 September 2016 - 09:28 PM
Yeah Gaffer the spire clips go onto that strip of aluminium you have there and it goes the other side of the clam below the exhaust heat shield. Mine rattles a little bit so I'm going swap that strip of ali for some  some L angle aluminium to give it a bit more stiffness. Ill probably put some rubber edging on my diffuser for aesthetics. Definitely looks a bit nicer.
#17 Nev
Posted 05 September 2016 - 09:09 AM
Do people regularly get on their hands and knees and inspect your under trays?
#18 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 05 September 2016 - 11:49 AM
poof
:drink: :lol:
#19 gaffer1986
gaffer1986
  • 4,408 posts
Posted 05 September 2016 - 11:54 AM
The paint was chipped off on the visible bit that sticks out.
#20 Nev
Posted 05 September 2016 - 04:02 PM
Oh golly, yes I can see how that would be of great importance. ;)
