Thinking Out Loud - A Vx Na Tuning / Itb / Sc Debate
Posted 22 August 2016 - 07:55 PM
Posted 22 August 2016 - 07:58 PM
Posted 22 August 2016 - 08:00 PM
Good call.... May combine well with option 1 or 2 Sent from my iPhone using Tapatalk5th : Gearbox with final lower drive
Posted 22 August 2016 - 08:13 PM
Posted 22 August 2016 - 08:26 PM
As a reference point cost wise.
Posted 22 August 2016 - 08:35 PM
Posted 23 August 2016 - 01:19 PM
Option one is a lot of fun. Changes the character of the engine. The benefits of the mods make their self felt mostly after 4,000 rpm so if is fun to be chasing the limiter.
Supercharging makes a lot of sense if you feel your car is too slow.
ITB is surely a very expensive way. But resulting in a very exciting drive.
Honda conversion is an expensive way to achieve the same power as option one, except of course you get a much higher rev limit.
I recently noticed I had not modded the engine in 4 years or so. I had not even noticed the transformation had stopped which suggests to me that I have found a sweet spot for my requirements. And don't get me wrong I a real enthusiast, I appreciate the car every time I get in.
And when are you going to make some more gaskets?
Paul
Edited by Paulus H, 23 August 2016 - 01:23 PM.
Posted 23 August 2016 - 01:33 PM
two threads on exactly the same subject in different places... FFS are you gunning for the Gaffer189343732576359864578632876329842 prize?
Posted 23 August 2016 - 01:46 PM
There can be only 1 Gaffer
Posted 23 August 2016 - 02:42 PM
I have also found the sweet spot for my vx.
I am very happy with the current engine and gearbox package, for a change
Edited by vocky, 23 August 2016 - 02:42 PM.
Posted 23 August 2016 - 02:49 PM
Drive/keep it as it was intended......Standard
Posted 23 August 2016 - 03:08 PM
Posted 23 August 2016 - 03:12 PM
Edited by pete-r, 23 August 2016 - 03:17 PM.
Posted 23 August 2016 - 03:55 PM
Sorry, my bad!!!!! Sent from my iPhone using Tapatalktwo threads on exactly the same subject in different places... FFS are you gunning for the Gaffer189343732576359864578632876329842 prize?
Posted 23 August 2016 - 03:56 PM
Hi Pete - that would be great. Will have to meet up some time. Where in Swansea are you? Sent from my iPhone using TapatalkSC in Swansea here happy to help If you want a back to back with yours. Another consideration is cost of repair. If you break a tuned engine it's going to cost a fortune to redo, whereas the sc is bolt on and you could source a replacement engine cheap should the worst happen.
Posted 23 August 2016 - 03:57 PM
Hi Paul, Going to be making some more next week. You never know, if I sell several thousand pairs it might find the upgrades!!! Mat Sent from my iPhone using TapatalkOption one is a lot of fun. Changes the character of the engine. The benefits of the mods make their self felt mostly after 4,000 rpm so if is fun to be chasing the limiter. Supercharging makes a lot of sense if you feel your car is too slow. ITB is surely a very expensive way. But resulting in a very exciting drive. Honda conversion is an expensive way to achieve the same power as option one, except of course you get a much higher rev limit. I recently noticed I had not modded the engine in 4 years or so. I had not even noticed the transformation had stopped which suggests to me that I have found a sweet spot for my requirements. And don't get me wrong I a real enthusiast, I appreciate the car every time I get in. And when are you going to make some more gaskets? Paul
Posted 23 August 2016 - 04:47 PM
Posted 24 August 2016 - 07:29 AM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]There is a forth option, which is do nothing and enjoy it as it is.... On a recent blast with a mixture of Elise's I noticed there was very little difference between my NA, a 118hp s1 and a 190hp s2 in the real world...[/color]
I think the answer lies within the concept of the word[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] "Lard" [/color]
Posted 24 August 2016 - 07:37 AM
Can diy sc stage 1 really be done for £1k - seems a bit optimistic? Sent from my iPhone using TapatalkAs a reference point cost wise.
Posted 24 August 2016 - 08:37 AM
1000 is very optimistic.
Maybe using cheap 2nd hand SC parts from US & shipping, plus a cheap SC remap (non OBD), but then you still need some bespoke new conversion parts (and the St1 pulley) and a few other bits that you can source 2nd hand. 1500 is more realistic.
Personally I would not bother with a non chargecooled SC, as that will loose a lot of power when it gets hotter;
Stage 2 => cheap vertical big oil cooler up front, some hoses & clamps. A waterpump + relay and a small watertank is all you need extra...
