I am not happy with my rear end grip and wants to improve this as I think it is a bit to oversteer to my liking.
I know it can be compensated by removing grip from the front end
but I prefer if possible to increase grip in my rear end and is now thinking about lowering my engine.
My Honda K engine is a bit taller then the Opel engine, but I never really pushed the car with my Opel engine.
Currently my oilpan is sitting somwehere 10-15mm above my underpanel reference plane and I am both thinking of make changes to oilpump
and oilpan and guessing I could gain around 20mm here and then I also thought about lowering down my oilpan to the same level as underside of underpanel and therefor I should be able to lower my engine somewhere around 30 mm.
So 2 questions comming up. Lowering the engine will help I am sure but will it be noticable when lowering it 30mm?
Cutting in my underanel I´m thinking around 10mm gap around the oilpan. Will it change the aerodynamics? If I make the oilpan complete flat
and compensate by removing one of the NACA duct, Its not completely flat here anyway because of the service panelunder the oilpan.
Any thoughts?
Br, Per
