This morning on the drive to work I pulled out of a junction and gave the VXT some medium throttle only to be greeted with a LOT of misfiring and a engine management light, which stayed on.
My initial thought was water had got into the coil/spark plugs ( i washed the car yesterday ), however I had a look and everything looked bone dry in there.
I've read that I should remove the coil pack and spark plugs and clean them up in case water is sitting under the pack. I have had a bit of misfiring under heavy load in 4th/5th gear as well, figured that I would get some new plugs and just put them in as I've got no idea how old the current ones are.
What should I be running for a stage4 turbo? It's got a Courtney stage4 map if that makes any difference.
I used to run coppers in my 330BHP 3SGTE, 1 grade cooler than stock. BKR7E. It ran like complete turd with Iridium, I guess that's not the case with the VX?
I see the standard plug for the Z20LET is BKR5EK, does that mean I should just go one colder and get BKR6EK? Or do I need 2 colder with stage 4?
I could check what is already in there right now, but I was hoping to go and pick up a set on my way home.
