Faut Code Po136
8 replies to this topic
#1 Speedy01
Speedy01
  • 30 posts
Posted 31 August 2016 - 05:12 PM
Hello, I have the following fault code on my VX turbo: P0136 (4) o2 sensor circuit open (bank 1 sensor 2) - present I have measured and cleaned the Lambda but nothing changed. Any suggestions as to what could be the problem? Many thanks.
#2 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 31 August 2016 - 05:17 PM
Have you checked both ?Change it ? Bank 1 sensor 2 is the one after the cat if I am correct
Edited by christhegasman, 31 August 2016 - 05:18 PM.
#3 Speedy01
Speedy01
  • 30 posts
Posted 31 August 2016 - 05:25 PM
Do you mean the lambda? I have not changed it but I measured 5.6 Ohms between the 2 wires of the same color.
#4 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 31 August 2016 - 06:55 PM
Is that what it should be ? I am not sure but if the resistance is wrong the code comes up Get a genuine one and change it save twatting about
#5 Speedy01
Speedy01
  • 30 posts
Posted 31 August 2016 - 07:08 PM
You're certainly right. I'll try to get hold of the reference and buy one.
#6 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    rugby
    eating out
    keeping fit
Posted 01 September 2016 - 08:11 PM
Get a genuine one don't get cheap eBay stuff if it works at all it will soon fail
#7 AstonVauxhall
AstonVauxhall
  • 644 posts
Posted 02 September 2016 - 07:54 AM
FYI
VXT Front - 9193148
VXR Rear - 9201421
N/A Front - 12569391
N/A Rear - 12567680
thumbsup
#8 slindborg
Posted 02 September 2016 - 08:00 AM
The two wires of the same colour are the heater, should be something between 10 and 20 ohms. but that code is for a low voltage on the output as opposed to the heater
#9 Speedy01
Speedy01
  • 30 posts
Posted 05 September 2016 - 09:24 AM
I've ordered a new one. I'll keep you informed if it solved my problem. Thanks for the help.
