Something has happened to my VXT (Stage4 Courtney), it's got a lumpy idle hot & cold, sort of surges between 500-800rpm on idle. It's in a pattern, like idles okay for maybe 5-10 seconds and then dips and rises then okay again for 5-10 seconds. Repeat.
It's like this video someone has posted on youtube, but it drops a bit lower before recovering: https://www.youtube....h?v=IB7IlT6KCF8, there's no solution on the video unfortunately though.
I've basically tried most of the suggestions I've found on the forum, the cheapest options anyway.
http://i142.photobuc...VacuumPipe1.jpg
I have checked the vacuum hoses can't find any leaks, I pulled off the hose on the above image labeled 'Vacuum box RHS' and covered the nipple ( ) didn't seem to change anything. Covered the end of the pipe too. The bit that goes to the bottom of the throttle body is really stuck on, I can't pull it off and I have zip tied around the FPR and T joints I can get at. The only bit I haven't been able to fully check is the BCS because it's very hard to get at from above.... ( any tips )?
I have also tried 2 sets of plugs:
- BKR6EK ( Platinum and 1 grade cooler than stock I believe )
- BKR7EIX ( Iridium and 2 grades cooler I think )
Both sets were brand new before they went in, I thought the 7's might have been causing it because they were too cool, however it's the same with the 6's. It does feel like overall it runs smoother with the BKR6EK.
I gapped the 7's to 0.7mm but the 6's can't be gapped I don't think as the design is a bit different. They are like this: https://c1552172.ssl...121713_x800.jpg
The car has only done 28K.
I saw on here about disconnecting the AMM, which I did and the car nearly stalled, but then recovered and idled a bit higher; still seemed to have it's lumpy seeking revs. I guess that means the AMM is okay?
Would the next step be coil pack? Can the coil pack cause bad idle even though the car seems to run fine under boost? I did remove the coil pack and clean it all up, including the springs and where they connect inside the rubbers. It didn't seem that bad really, minimal corrosion.
Sorry for a long post....
Edited by james4563, 14 October 2016 - 09:22 PM.
