Loose Drivers Seat!
Posted 26 October 2016 - 08:59 AM
Posted 26 October 2016 - 09:11 AM
It can only be the four bolts that hold the runners to the floor, the bolts at the side near the angle of the seat or the nuts underneath the front of the seat that secure it to the runner joining plate (for the latter you have to take the seat out)
Edited by fiveoclock, 26 October 2016 - 09:11 AM.
Posted 26 October 2016 - 09:29 AM
I really wouldn't recommend tightening the bolts 'as tight as they can go' because they go into aluminium. Chances of threading it is very high.
The drivers seat runners can develop some play. Also take the seat out and check the two nyloc nuts attaching the base of the seat to the runner.
Posted 26 October 2016 - 09:41 AM
Trouble is, I can't keep away from a problem! I've had another look...The rail is a steel channel running in a steel channel. There are no hardened bearing surfaces, so it's gonna wear pretty quick if you keep moving the seat back and forth. As I said before, lateral play can be improved by pinching the outer in a vice. The vertical play (which I guess you people are suffering from more), is taken up by a series of pressed indents (like notches) along the top of the outer channel. These won't last five minutes with you habitual shufflers.You can do a temporary fix by knocking these indents in further I guess, but a better fix would be to introduce some hard rubber blocks between the inner and outer channel.Seasoned seat-movers should source a ball-bearing type runner and get someone to adapt it to the frame.Steve
Posted 26 October 2016 - 10:47 AM
Seat rail bolts that go into the chassis beams actually thread into steel.
At the front there's weldnuts on small steel strips bonded inside the (hollow) chassis beam. On the back there are steel threaded reinforcement plates bonded into the chassis beam itself.
Can still strip 'em of course if you're brutal enough, but at least a lot less quick than if they were just threaded into ali
But like above.. Usually any rocking is not in the bolts, it's most of the time play in the slider mechanism itself..
Posted 26 October 2016 - 11:14 AM
..or ..get some really firm foam and stuff it down behind the seat...this also stops sh*te falling down underneath from the shelf
HH
Posted 26 October 2016 - 11:52 AM
Thought this is due to play in the steel bearing balls in the slider mechanism. On the German forum they had a group buy once for slightly bigger steel balls that seemed to work, only the sliding was a bit harder to do...
Posted 26 October 2016 - 07:29 PM
I had the issue with the driver seat too. I guess everybody gets it sooner or later. Wanted to replace the bearing balls with the "first oversize" but could only change the rear bearing balls. The oversize wouldn't fit into the front, not enough worn out. Now the rattle issue of the seat is fixed but I can only move it when sitting in it. Wouldn't be much of a problem but I need to move it forwards to place the softtop behind the seats which is not very comfortable now.
Posted 26 October 2016 - 08:18 PM
I've had this issue with both my VX220s and both times it was the two nyloc nuts under the seat, you need to take the seat out with the runners connected to see.I really wouldn't recommend tightening the bolts 'as tight as they can go' because they go into aluminium. Chances of threading it is very high. The drivers seat runners can develop some play. Also take the seat out and check the two nyloc nuts attaching the base of the seat to the runner.
Posted 27 October 2016 - 08:35 PM
Posted 28 October 2016 - 07:40 AM
Undoing these seat bolts was one the most frustrating jobs I've ever done, and I had to remove both seats too.
Posted 28 October 2016 - 11:50 AM
Really not that difficult with the right tool...
Refitting them.... that is the spectacularly fun job.
Posted 28 October 2016 - 12:14 PM
Passenger seat front left allen bolt is the tricky one, I bought 3 tools none of which helped much.
Posted 28 October 2016 - 06:47 PM
I adapted one of those Halfords ratchet spanners and a driver with a bit of tape around it, did the job a treat. Although still not something I particularly want to do again.
Posted 29 October 2016 - 06:14 AM
That's the best combo. It is the fun of getting the bolt located and then managing to get bit in it without knocking it out that will drive you barmyI adapted one of those Halfords ratchet spanners and a driver with a bit of tape around it, did the job a treat. Although still not something I particularly want to do again.
Posted 30 October 2016 - 09:27 AM
Have you got a photo?
Posted 30 October 2016 - 03:53 PM
Unfortunately not, but if you get one of those short hex/allen-key drivers to fit the seat bolt and one of those fine ratchet spanners 10mm I think, and wrap some tape around the hex driver so it doesn't drop off before locating you then have to just put a finger on the seat bolt so it doesn't just rotate back.
In conclusion this must have been one of the worst jobs in the factory no doubt about it.
Posted 30 October 2016 - 03:57 PM
Cheers. I bet they had a bespoke tool for it, would save a lot of time.Unfortunately not, but if you get one of those short hex/allen-key drivers to fit the seat bolt and one of those fine ratchet spanners 10mm I think, and wrap some tape around the hex driver so it doesn't drop off before locating you then have to just put a finger on the seat bolt so it doesn't just rotate back. In conclusion this must have been one of the worst jobs in the factory no doubt about it.
Have you got a photo?I adapted one of those Halfords ratchet spanners and a driver with a bit of tape around it, did the job a treat. Although still not something I particularly want to do again.
