Good afternoon.
Im currently collecting parts for my Supercharger (Build thread on the way) and have been looking into the PCV valve fitted in the LSJ inlet. I looks the same as that fitted to Saabs and from what i see is another emission control through burning off any oil vapour from engine casing, preventing vent to atmosphere.
The valve on mine is shot and air can pass either way so the system has failed. This has caused oil contamination of the cooler fins and being such a fine setup it doesn't take much.
My question is this, has anyone blanked the pcv in manifold and pipe from inlet pipe and run a catch tank from cam cover or is it best to just replace the valve (if so, where is best to get them?)?
My biggest worry is if doing this causing over pressurisation somewhere within.
Many thanks
