Anyone know the size of the o ring needed for the oil filter cap on the 2.2 ??
Are they still available or is there a shortage ??
Posted 16 November 2016 - 09:57 AM
Posted 16 November 2016 - 10:12 AM
O ring = 65mm ID x 3mm
vauxhall part number = 9197883
Posted 16 November 2016 - 10:20 AM
Thank you Vocky - will get this engine right in the end.
Posted 16 November 2016 - 03:21 PM
Edited by tibby, 16 November 2016 - 03:25 PM.
Posted 24 April 2017 - 01:57 PM
Did anyone try and test any suitable replacements for this o-ring?
Did an oil change today and found mine is a gonner too.. no where has the original parts in stock
Posted 24 April 2017 - 02:09 PM
This seems odd, didn't you sell me some of these o rings a while back????Anyone know the size of the o ring needed for the oil filter cap on the 2.2 ?? Are they still available or is there a shortage ??
Posted 24 April 2017 - 02:13 PM
This is the investigation thread prior to the selling thread.
Edited by Johnboyhgt, 24 April 2017 - 02:14 PM.
Posted 24 April 2017 - 02:22 PM
I found a source though I'm out at the moment and its a 25 piece minimum order.
Posted 24 April 2017 - 03:02 PM
Any particular things that need to be considered other than the size? I see o rings are available in loads of different types of rubber variants.. just something high temp and oil resistant?
Posted 24 April 2017 - 03:31 PM
Posted 24 April 2017 - 04:19 PM
Posted 17 August 2018 - 04:57 PM
Cannot find part number 9197883 anywhere. Any body know if these are available please?
Posted 17 August 2018 - 06:35 PM
Just go on to eBay and order a 65x3mm Viton O ring, there are lots of people who do them in bulk or singly. Ordinary general purpose Viton is good for more than 200C.
Posted 31 August 2018 - 10:11 PM
Just got some, but are the wrong size too big. Are you sure this is the right size for the 2.2 engine?
Posted 01 September 2018 - 07:34 AM
9197883 is the correct part number
part number 14 on the EPC = https://www.speedste...lter/index.html
If the seal is too big it will be a standard O ring seal for the astra/vectra/zafira
Posted 01 September 2018 - 08:30 AM
Have just clocked two original OEM O rings, one still unused in it's bag and the other used in it's bag, both part number 9197883, and they are both definitely 65mm i/d X 3mm diameter.
