I still use my old tower with xp to sync and update my I tunes stuff on my 6plusits 10 years old. Its slow. It takes up too much space (hence I want a laptop) It runs XP, which isn't compatible with my iphone and itunes anymore (they didn't mention that when I got a new iphone so I can't sync it and get my music onto my phone)ewwww laptops serious question, is there anything actually wrong with your PC?
Laptop Advice
#21
Posted 24 November 2016 - 03:49 PM
#22
Posted 24 November 2016 - 08:28 PM
#23
Posted 24 November 2016 - 08:31 PM
ahh odd didn't realise it was any different in operation to the 6 ?Doesn't work with the iPhone SE with XP unfortunately
#24
Posted 24 November 2016 - 09:08 PM
#25
Posted 15 December 2016 - 10:58 AM
that's the what I meant, just a bit more explained then "ewwwwwwwww" A laptops shelf life is far shorter then a PC, unless you know how to rebuild it? However maintenance or preventative maintenance does not seem like something you want to do. Laptops are good and serve a purpose but unless you keep on top of it, will become slower then your current PC. Have you considered just getting some upgrades to your current PC? It might be out the question if you cant get that generation of components. I don't know what your mobo is compatible with. But a few more RAMs and a fresh install on a SSD will speed up the PC beyond recognitionMaking things small costs. A £200 desktop will always outperform a £200 laptop. Batteries also cost money, as does a screen, keyboard etc. Which is all factored into the cost of a laptop. So if you don't NEED a laptop (assuming you already have a keyboard, mouse, screen etc from your old PC) consider a cheap / used desktop. Just bear in mind a sub £200 laptop will be built to fit a market need. I.E. people that want a sub £200 PC. So just be aware it will be built with the cheapest components available. Don't expect it to stay "fast" for very long or the battery to last (hold a good enough to charge to use it unplugged) very long.
#26
Posted 15 December 2016 - 11:51 AM
Really, can you explain how?
#27
Posted 15 December 2016 - 12:06 PM
The processor gets tired as it gets older and also the RAM forgets stuff.
#28
Posted 15 December 2016 - 01:13 PM
Applications and system process' use computer resources and the more you use it the more there will inevitably be. Hard disks slow over time and bad sectors appear and the way things are saved ununiformed, I don't know why it does that. PCs usually have more resources so you not notice the slow down as much.. All computers need preventative maintenance but more so laptops. Also laptops unless mega expensive have cheaper components and wont last as long.. IMO since smart phones and powerful tablets come out there has been little to no need for laptops.Really, can you explain how?Laptops are good and serve a purpose but unless you keep on top of it, will become slower then your current PC.
#29
Posted 15 December 2016 - 01:43 PM
His current PC is 10 years old, any new laptop will have much higher resources (plus it will be 64bit)
In my experience a laptop needs no more maintenance than a desktop PC. (my experience is 20 years in the I.T. industry )
Your comment that a less powerful laptop will suffer more than a more powerful desktop is of course true but that has nothing to do with the architecture and everything to do with resources.
Edited by SteveA, 15 December 2016 - 01:44 PM.
#30
Posted 15 December 2016 - 01:55 PM
To answer the question of data uniformity. Data is split into blocks (4k blocks is the default size for NTFS) and is generally written to spinning disk sequentially, so a 32k file will take up 8 blocks. As data is deleted over time spaces become available and these spaces are indexed by a file allocation table. When the next item of data is to be written it is assigned empty space (it's not technically empty but that is another topic), the new file maybe 36K so it will use the 32k of free space and then find the next available space to write the rest. When a read of this data is requested it is not sequential so takes slightly longer to access, this is called fragmentation. Windows has tools that take these fragmented files and places their blocks sequentially again for faster read times.
Edited by SteveA, 15 December 2016 - 01:55 PM.
#31
Posted 15 December 2016 - 02:22 PM
#32
Posted 15 December 2016 - 02:39 PM
I'm not arguing, i just thought some of your comments could have been a bit misleading to the OP . I agree that a £200 PC will be better than a £200 laptop. I'm just saying that any new PC will be better than a 10 year old one.
Anthropomophism at its finest
#33
Posted 15 December 2016 - 03:05 PM
Or MFT in the case of NTFS?
You may find that a reinstall every couple of years makes a difference if using Windows.
#34
Posted 15 December 2016 - 03:15 PM
Not sure, there is some allocation table there but its been a long time since I've looked at NTFS. I'm more of a VMFS and UXFS person these days.
#35
Posted 15 December 2016 - 03:33 PM
Wow, lots of to-ing and fro-ing on this subject today.
All your advice has been appreciated.
I got a new laptop on Black Friday.
It was a cheapy (£110) and it does what I want, currently quicker than my old desktop did.
The things I wanted it for were (in no particular order)....
To be able to sync with my iPhone 5SE (which XP won't do anymore)
To get back the space taken up by a desktop, monitor and keyboard.
To very occasionally log on remotely to my work server.
This does all of these things, and it'll only be used once every few months or so - most of my at home surfing is either on the phone or PS4.
I'm happy enough with my choice. If it lasts, great - if not, no biggie.
cheers
Michael
#36
Posted 15 December 2016 - 10:01 PM
#37
Posted 15 December 2016 - 10:17 PM
The only argument I can see for a laptop being worse than a PC is the battery will degrade in time and will need replacing (if possible).
I currently have a Surface Pro 3 i7 paid a fortune for it and have never looked back since It's companion is a Surface 3 I picked up of ebay for £150 notes (bargain as it was still under warranty and came with the keyboard!)
The problem I see nowadays with Laptops and PC's in the the Processor speeds and silly numbers etc... after each of them.
Quad Core 64bit Atom processor sounds fancy but is good for battery life (why I love my Surface 3) but the Quad Core Intel i7 64bit is 10 times more powerful which is why I love my Surface Pro 3 but runs hot and battery life is not so great. The price difference is eye watering which is where most people will change there mind, about a £1000 difference when both were new!
If you want a lovely basic laptop then any sort of Atom will do the trick but may not be great on website with lots of HTML5/Flash or sites with lots of adverts. The battery will be the first thing to go (unless you drop it and smash the screen lol). So getting one with a replaceable battery is a good idea and will extend the life of your laptop. I'm dreading my Surface Pro 3 when the battery becomes next to useless
What laptop did you buy muckyman?
#38
Posted 16 December 2016 - 07:52 AM
#39
Posted 16 December 2016 - 08:13 PM
Got a Lenovo Atom Processor Z3735F Ideapad 100S. 2GB RAM and a 32GB Hard Drive. Up to 8 hours battery life apparently. Already had a 500GB external hard drive so the storage limitations on it aren't a problem.
Not bad for the price mate!
#40
Posted 15 February 2017 - 12:50 PM
