Battery Replacement- Best £10 I Ever Spent!
Posted 22 November 2016 - 06:42 PM
Posted 22 November 2016 - 06:45 PM
lol i will remember this top tip, does help having another pair of hands when replacing a vx battery.
Posted 22 November 2016 - 07:08 PM
i just did this and the bolts holding the battery retention bracket have been rusted and snapped off a few years ago. Removing the battery without removing that bracket was..... tricky. But i got there in the end, helps that her indoors has little hands when i kept dropping my tools.
Posted 22 November 2016 - 07:09 PM
Edited for accuracyi just did this and the bolts holding the battery retention bracket have been rusted and snapped off a few years ago. Removing the battery without removing that bracket was..... tricky. But i got there in the end, helps that her indoors has little hands when i kept dropping my pants
Posted 22 November 2016 - 08:47 PM
I couldn't be arsed to changed my battery once so rang up and booked a replacment with an online company, £60 they said, 2 hours later I had a phone call saying they couldn't do it as it was a "Two Man Job", ordered a battery and did it myself in the end, it is a PITA but once it's done it done, i've replaced 3 batteries in my 5 years of ownership! Now it's left on trickle charge.
Posted 23 November 2016 - 08:35 AM
I'd be concerned with the damage a Halford's numpty might do to the whole area. I've learnt over the years to be VERY cautious about who I let work on my cars.
Posted 23 November 2016 - 08:36 AM
Trickle charging is deffo the way to do things if it's a second/weekend car with infrequent use. So easy to do, just plug the charger into the cigarette point.
Edited by Nev, 23 November 2016 - 08:45 AM.
Posted 23 November 2016 - 09:44 AM
how many still left on oem battery?
Posted 23 November 2016 - 09:54 AM
Didn't realise that. So with the VX I can just buy a plug in that fits the cig lighter in the centre tunnel?Trickle charging is deffo the way to do things if it's a second/weekend car with infrequent use. So easy to do, just plug the charger into the cigarette point.I couldn't be arsed to changed my battery once so rang up and booked a replacment with an online company, £60 they said, 2 hours later I had a phone call saying they couldn't do it as it was a "Two Man Job", ordered a battery and did it myself in the end, it is a PITA but once it's done it done, i've replaced 3 batteries in my 5 years of ownership! Now it's left on trickle charge.
Posted 23 November 2016 - 12:38 PM
Yep
Posted 23 November 2016 - 04:43 PM
Posted 23 November 2016 - 04:56 PM
If you want to be safe with charging into the cigarette point , make a second one with thicker wires and a direct connection to the battery. Not every charger is the same and it would be not the first car who's electrical system would be messed up. (burned wires etc....) Better safe than sorry..... BTW , it's only a 1 minute job to open the bonnet,lift the watertank out and connect the charger :-)YepDidn't realise that. So with the VX I can just buy a plug in that fits the cig lighter in the centre tunnel?Trickle charging is deffo the way to do things if it's a second/weekend car with infrequent use. So easy to do, just plug the charger into the cigarette point.I couldn't be arsed to changed my battery once so rang up and booked a replacment with an online company, £60 they said, 2 hours later I had a phone call saying they couldn't do it as it was a "Two Man Job", ordered a battery and did it myself in the end, it is a PITA but once it's done it done, i've replaced 3 batteries in my 5 years of ownership! Now it's left on trickle charge.
Edited by tibby, 23 November 2016 - 04:58 PM.
Posted 23 November 2016 - 05:04 PM
Posted 23 November 2016 - 06:52 PM
This is indeed the BEST solution!!! :-)And if you get a ctek it comes with an adaptor that you leave attached to the battery so plug in is a 2 second job.
Posted 23 November 2016 - 07:27 PM
I'll second that. The ctek was the best £45.00p I ever spent.
Mine charges through one of the two aux points under the dash.
Edited by Ian59, 23 November 2016 - 07:29 PM.
Posted 27 November 2016 - 11:57 AM
Yep, defo the best charger:
https://www.amazon.c...1&keywords=ctek
and this is the easy access ciggy thingy:
https://www.amazon.c...6&keywords=ctek
My brother-in-law and his mates keep borrow mine, but I do have a spare solar panel charger that I use during the summer, just hook it to the outside of the garage and even better
Posted 27 November 2016 - 12:24 PM
Posted 27 November 2016 - 04:07 PM
It is but if your a lazy sod and can't be arsed connecting it up or opening the bonnet to disconnect and re connect every time you fancy a spin use the cig lighter socket which has a 20 amp fuse and wiring so will eat the job 👍This is indeed the BEST solution!!! :-)And if you get a ctek it comes with an adaptor that you leave attached to the battery so plug in is a 2 second job.
Posted 27 November 2016 - 08:16 PM
Posted 27 November 2016 - 08:34 PM
