#81
Posted 05 May 2017 - 08:11 PM
#82
Posted 05 May 2017 - 10:35 PM
and runs out of fuel
#83
Posted 05 May 2017 - 10:37 PM
Which is probably 5 in reality.The 400 is sooo much more fuel efficient with the newer supercharger
6.8mpg at Spa.
#84
Posted 05 May 2017 - 10:45 PM
#85
Posted 05 May 2017 - 10:48 PM
#86
Posted 05 May 2017 - 10:55 PM
#87
Posted 05 May 2017 - 11:02 PM
#88
Posted 06 May 2017 - 10:24 AM
Yeah, I was working away againTrackday was yesterday
Gates 5pk1280 fit to inside rib leaving outside rib empty
#89
Posted 06 May 2017 - 11:23 AM
#90
Posted 06 May 2017 - 01:04 PM
Thanks Joe - what does the 1290 refer to? Regarding the misfire: http://www.vx220.org...load/?p=1919807Yeah chuck it on
Edited by Foxy, 06 May 2017 - 01:05 PM.
#91
Posted 06 May 2017 - 01:17 PM
Also regarding the misfire...
#92
Posted 06 May 2017 - 01:20 PM
By the way, what hose do i need for the short vacuum hose off the supercharger?
The length.
#93
The length.
In mm.
#94
Posted 06 May 2017 - 01:25 PM
lol oops! bits of cat trying to escape?!
#95
Posted 06 May 2017 - 01:27 PM
In mm.
Thanks Mark. So different length is taken up with the tensioner? Is it an easy job?
#96
Posted 06 May 2017 - 04:46 PM
Very easy if you know what you're doing ![]()
through the wheel arch ![]()
#97
Posted 06 May 2017 - 05:31 PM
Sod that...think of all the seized fasteners!Very easy if you know what you're doing
#98
Posted 06 May 2017 - 05:53 PM
Can be done from the top if you have nimble enough hands and right size ratchet. Baby talc sometimes helps as a temporary fix 👍so now you have another use for it 😄Sod that...think of all the seized fasteners!Very easy if you know what you're doing
#99
Posted 06 May 2017 - 06:07 PM
cornflour is cheaper and as a talc less likely to cause skin problem
#100
Posted 06 May 2017 - 08:34 PM
Thanks, will try that. Anyone know if driving with a knackerd cat will damage the engine?cornflour is cheaper and as a talc less likely to cause skin problem
