Well today I finally decided that I should attempt to remove the pre cat.
Hands are all cut up and I'm absolutely filthy but the bugger is out
There are a couple of annoying fiddly bolts, but most of it was straight forward.
Getting the actual pre cat out was fun... not!
At that point i though "oh my god what am I doing!" but it was too late to stop now.
After about 45minutes hammering, the bugger came out.
Assembled back together with no real problems.
Started the car and it seems to burble a bit deeper now. Lots of smoke rose from the back and I thought WTF! Then I remembered I soaked everything with WD40.
btw here's the tools that you'll need...
Sockets
8mm
10mm
13mm
Spanners I'd definitely recommend those flat wrench type. You might not cut your hands so badly as mine
13mm
10mm
1 set of wheel ramps or two goods jacks.
1 philips head screwdriver
1 SHARP chisel
1 heavy duty hammer (I used a mallet)
1 workmate or vice
1 drill with a metal head drill
1 grinder to clean the inside of the pre cat (I used a hobby mini grinder for this)
1 good torch!
lots of WD40!!!
and..
lots of patience and time
I think thats all the tools you need.
I haven't had a chance to take her for a spin yet but once I do i'll let you all know how she's performing.
off to the shower now..
Colin
btw I'm happy to supervise anyone elses pre cat removal as long as I don't have to get my hands dirty again
Edited by BogBrush, 10 May 2003 - 04:23 PM.
