Knocking Anti Roll Bar Question
Posted 08 December 2016 - 10:37 PM
So I have a loud knocking coming from the n/s/f that I'm sure your all aware can become very irritating in a car with no sound insulation.
I self diagnosed to be the anti roll bar as when I go over cats eyes with the off side the near side knocks. The car has an aftermarket 1"? ARB.
After taking her along to my local garage they say the knocking is coming from the mountings attached to the chassis and there is no visual rubber or bushing on these mountings?
My question is.. Is this normal to have metal to metal? And also where can I buy new ones?
Thanks for reading guy and any help would be seriously appreciated.
Sent from my Nexus 5 using Tapatalk
Posted 09 December 2016 - 08:42 AM
Difficult to see what's happening there. Joe's linked pictures show the intended arrangement and I can't see the aluminium bracket on yours?
The hard plastic 'bush' has a reputation for creaking if not lubricated (mine were dreadful). I think I'd first check whether the bar is loose in those mounts (the second picture appears to show a gap?). If it is, then new mounts. If it's rigidly mounted, strip and lubricate.
Posted 09 December 2016 - 09:32 AM
Posted 09 December 2016 - 09:56 AM
CF supply a replacement all plastic mount James? Which I assume then wears?
For ID purposes, CF are orange (similar to the pic), EP are red?
That's indeed a Cornering Force ARB with some special mounting blocks.
Did you check if the mount bolts are not loose?
Posted 09 December 2016 - 07:03 PM
Posted 09 December 2016 - 07:05 PM
Fitted from new there was always a good degree of freedom in movement in the CF ARB. I've got a rattle over choppy road surfaces which I have put down to pad/disk rattle, as it goes immediately a small amount of breaking force is applied.
Posted 10 December 2016 - 10:15 AM
Yep, iv got the same issue, i run CL5+ pads.Fitted from new there was always a good degree of freedom in movement in the CF ARB. I've got a rattle over choppy road surfaces which I have put down to pad/disk rattle, as it goes immediately a small amount of breaking force is applied.That's indeed a Cornering Force ARB with some special mounting blocks. Did you check if the mount bolts are not loose?
Posted 10 December 2016 - 06:49 PM
That's the pads I run as well...I think it is well known that they rattle...annoying to say the least!Yep, iv got the same issue, i run CL5+ pads.Fitted from new there was always a good degree of freedom in movement in the CF ARB. I've got a rattle over choppy road surfaces which I have put down to pad/disk rattle, as it goes immediately a small amount of breaking force is applied.That's indeed a Cornering Force ARB with some special mounting blocks. Did you check if the mount bolts are not loose?
Posted 10 December 2016 - 11:45 PM
Posted 11 December 2016 - 02:53 PM
Speak to Simon at CF, very helpful. I've always had first class service from them.Thanks for all your replies and ideas guys. Once cornering force was mentioned, I immediately remembered seeing some stuff in my paperwork from them and right enough, buttons and ARB kit was indeed purchased In 2011 with dunno graphs showing all the different corner weights etc under different loads and dampening settings. Quite cool actually! I noticed on the fitting instructions it comes with black derlin mountings. As little miles the car has done it doesn't surprise me that being high compound plastic they may have deteriorated or worn. I'll maybe check for my self first whether they may just be loose. If not I'll contact the fellas at cornering force to see about replacing. Sent from my Nexus 5 using Tapatalk
Posted 11 December 2016 - 05:12 PM
Posted 11 December 2016 - 05:15 PM
Here are some better pics showing the gap I took today with the nearside jacked up.
Posted 11 December 2016 - 05:18 PM
And here is a pic of the bottom once the offside is alone jacked up forcing the bar to the top.
Looks like the powder coating has worn away, maybe the mounts are fine after all?
Posted 11 December 2016 - 06:59 PM
Posted 11 December 2016 - 08:20 PM
So did you check if the 2 mounting block bolts are torqued up? Looks like a significant gap between both mounting halves...
Posted 11 December 2016 - 09:01 PM
Posted 11 December 2016 - 09:02 PM
