Laminova Tapered Washers Which End ?
6 replies to this topic
#1 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 13 December 2016 - 04:03 PM
Hi all
Slight schoolboy error, forgotten which end the slightly tapered larger washer goes on the laminovas, is it end plate end or inside the manifold end.
John
#2 Exmantaa
Posted 13 December 2016 - 05:39 PM
=Laminova core = large thin washer = thicker washer = 0-ring =
Just make sure the core o-ring surface has no damages and best use some silicone lube on the o-ring...
#3 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 13 December 2016 - 06:35 PM
Thank you for reply but four of the larger washers also have a slight taper on them - where do they go ? Sent from my SM-G903F using Tapatalk
#4 Exmantaa
Posted 13 December 2016 - 08:31 PM
the large thin washer is maybe 0.5mm thick, so not much of a taper there. The thicker ones sometimes are a bit 'taperisch" due to manufacturing, but fitting orientation does not matter. It's just a spacer.for the o-ring seals.
#5 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 13 December 2016 - 11:06 PM
Perfect. Thank you for the information. John Sent from my SM-G903F using Tapatalk
#6 Exmantaa
Posted 14 December 2016 - 12:20 AM
ps; you said "4 washers", but both ends of the Laminova cores are sealed the same.
So you will need 8 O-rings, 8 large thin washers and 8 thicker washers...
#7 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 14 December 2016 - 08:51 AM
Yes i meant the ones in the depths of the manifold rather than the end plate ones
