Nitron Ntr 40 - Eye Spacer Fitment
12 replies to this topic
#1 harboged
harboged
  • 392 posts
Posted 06 January 2017 - 11:41 AM
I was about to install my new Nitrons when I noticed that some of the spacers (shown in attached photo) didn't slide into the eye.
It appears that three out of twelve spacers have a diameter small enough to let them slide in without any force at all. The other nine spacers have a different diameter, 0.02mm larger than the diameter of the eye's hole. These can probably be press fitted using a vise but what happens the day I want to remove them? I don't want to risk damaging the dampers.
Seriously Lotus, from whom I bought the dampers, have never heard of this before and say they always slide in easily.
So my question is, should these slide in easily, or has Nitron changed the design? Perhaps I have got a mix of old and new spacers?
Cheers
#2 Nev
Posted 06 January 2017 - 11:56 AM
I had the same issue. I used a vice or a small knock with a hammer to fit them.
In my case I could get them out (from the other side) with a screwdriver and hammer to tap them out. Simples.
#3 Andy_VX
Andy_VX
  • 2,050 posts
  • Interests:Cars, Boats, F1, Cycling, Home Cinema, Music.
Posted 06 January 2017 - 12:04 PM
I was under the impression they came in 2 different sizes, when I changed from the 46's to 40's I had to change the spacers.
I'd ring Nitron to clarify.
#4 harboged
harboged
  • 392 posts
Posted 06 January 2017 - 12:06 PM
I had the same issue. I used a vice or a small knock with a hammer to fit them.   In my case I could get them out (from the other side) with a screwdriver and hammer to tap them out. Simples.
OK, that sounds good :) And now when I'm fully awake I realise that I only need eight spacers but got twelve...
#5 harboged
harboged
  • 392 posts
Posted 06 January 2017 - 12:11 PM
I was under the impression they came in 2 different sizes, when I changed from the 46's to 40's I had to change the spacers.    I'd ring Nitron to clarify.
Ah, I see. Yeah, I have emailed them and i'm waiting for their reply. Cheers
#6 harboged
harboged
  • 392 posts
Posted 06 January 2017 - 12:22 PM
Now I'm even more awake and in the garage again, and realise that 12 spacers are needed after all :D Instead I'm missing two o-rings...
Edited by harboged, 06 January 2017 - 12:23 PM.
#7 ufods
ufods
  • 235 posts
Posted 06 January 2017 - 12:44 PM
Cool them down and knock them in...
#8 Exmantaa
Posted 06 January 2017 - 01:14 PM
 4 shocks x 2 eyelets x 2 spacers each side = ??
#9 harboged
harboged
  • 392 posts
Posted 06 January 2017 - 02:02 PM
(2 rear shocks x 2 eyelets x 2 spacers) + (2 front shocks x 1 eyelet x 2 spacers) = 12 The fronts have the 4 upper spacers already installed from factory
#10 siztenboots
Posted 06 January 2017 - 02:27 PM
the fronts can on some have two extra outboard spacers at the top bolt, these need to be fitted so the large diameter surface faces the shock, not the chassis
#11 harboged
harboged
  • 392 posts
Posted 06 January 2017 - 02:57 PM
This is how the top spacers were installed at the factory.
#12 siztenboots
Posted 06 January 2017 - 03:03 PM
they are now a one piece design , previously top and bottom had the same width inserts.
#13 smiley
Posted 06 January 2017 - 03:07 PM
I would say those are the wide spacers that come with the wider nitron brackets.
Thinner spacers fit the oem brackets.
