Selling this to fund the next vx220 project.
May be of interest to someone on here?
http://www.pistonhea...ve-spec/6671964
Many thanks
Dan
Posted 14 January 2017 - 12:06 PM
Many thanks
Dan
Posted 14 January 2017 - 12:13 PM
Nice car what are your plans with vx ?
Posted 14 January 2017 - 12:22 PM
Thanks Lee.
I have put a deposit down on a green vx220 with a forged supercharged NA with good track mods.
My plan is to loose as much weight as possible from it, build a super short gearbox for it and pop a haroop supercharger on it when I've got track confident....seems you may be a good person to speak to at some point!
The car seems a good base to make it into a good track car, the biggest upgrades however will come from some seat time as im used to mx5's and Westfield's so no doubt will take some getting used to!
Dan
Posted 14 January 2017 - 12:23 PM
Wow, that thing must be fast as hell upto about 120 and it has a sequential gearbox no doubt
Edited by Nev, 14 January 2017 - 12:24 PM.
Posted 14 January 2017 - 12:28 PM
Wanna go halfs?!Nice car what are your plans with vx ?
Posted 14 January 2017 - 12:37 PM
I have absolutely no idea about westfield prices with bike engine conversions.
Is it loud?
Posted 14 January 2017 - 01:06 PM
i would of but just spent my half on engine parts for the 2.4 build not cheap
Posted 14 January 2017 - 01:20 PM
Yeah its a very sharp machine but its at the limiter in top at circa 120-125, its actually reasonably easy to drive just using revs up to 8k with the rotrex fitted and then can enter beast mode up to 12k when needed.
Going half's would make a lot of sense...these projects always end up costing more!
It is loud but has a big track friendly exhaust so is ok fro trackdays.
Dan
Edited by Danny Scarbro, 14 January 2017 - 01:22 PM.
Posted 14 January 2017 - 02:32 PM
is it just the aero screen?
Posted 14 January 2017 - 03:24 PM
Correct yes.
I did have a full windscreen to put on it but that adds weight and wind resistance so would make it slower hence it got sold!
Dan
Posted 14 January 2017 - 04:37 PM
If you are going to Harrop it i wouldn't bother putting a 4.17 gearbox on it gearing is to low stay with standard f23 gearbox i no i had 4.17 in mine .
just drop me a pm if you want a chat or anything good luck
Posted 14 January 2017 - 06:47 PM
Posted 14 January 2017 - 06:48 PM
Posted 14 January 2017 - 07:08 PM
Haggi has a 4.17 with a Harrop, he loves it. Owner preference I guess
Personally I have the same ratios as a 4.85 F23 and would not change it for anything else
Posted 15 January 2017 - 08:26 AM
Thanks Lee, My plan was to build a box using a 4.4 and a Quaife to put in, I worked out that with the current 17" wheels at the rear it would give an optimum speed of 145mph at 7k. (Still abit short as I'll never get up there on the tracks local to me) I'm interested as to why you wouldn't get on with a shorter final drive because of more power? The idea is to make the car as light and fun as possible upgrading the power when I get abit more confidence as I go. Dan
I just found that i tended to change gear more on track 1st gear was over very quick on pull of .as i increased the power it just pulled so well through the gears i changed the 4.17 gearbox back to standard and it drives better all my opinion .
I have a diff in mine well worth doing you can feel the difference around and out of corners .
Posted 15 January 2017 - 10:29 AM
Thanks Lee & Vocky, seems its is personal preference.
What is gained in acceleration is probably lost in gear changes but it should make for a more 'exciting drive' which is where I'd like to go with the project (even if it does sacrifice a few tenths on the lap times.)
Do you mind me asking what diff you put in Lee?
There is obviously the quaife available, is there any plated ones available, Kaaz? Gripper?
Dan
Posted 15 January 2017 - 11:16 AM
I put the [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]quaife in mine [/color]
Posted 16 January 2017 - 09:47 AM
Posted 25 January 2017 - 12:31 PM
Now sold
