Tuning, Where's My Money Best Spent?
25 replies to this topic
#21 chickendippers
chickendippers
  • 488 posts
Posted 17 January 2017 - 10:59 PM
It doesn't say that's the maximum available from a K04 at all. They can be pushed further, I've seen them run over 320bhp. More importantly the graph highlights where the K04 starts to run out of flow and where a K06 would be better higher up the revs
Water meth kit is imo the easiest and cheapest way to cool IATs. Brand new kits can be had for ~£350, well worth the investment.
#22 Nev
Posted 17 January 2017 - 11:18 PM
so according to the graphs , the k04 can only get 330 torque and 289 bhp
strange that on the same dyno , many years back in 2007 , the same turbo was making 360 torque and over 310 bhp
both turbo have the same CHRA and same exhaust turbine
something very wrong with this
Ha ha, the usual "selective marketing" to get the punters to spend spend spend. :(
There is no doubt the K06 will puff more than the K04 variants though, and keep IATs a bit lower when not maxed out.
The key problem with IATs is that everyone is pushing these titchy little turbos to twice the boost they are efficient at. Hence the IATs shoot up. If you want low IATs then the best way is to install a big(er) turbo that is actually operating at the flow rate and PR rates that it is designed to.
Edited by Nev, 17 January 2017 - 11:27 PM.
#23 gertje
gertje
  • 459 posts
Posted 18 January 2017 - 10:54 AM
Sticker tuning, each sticker increase the car 10hp � Verzonden vanaf mijn iPhone met Tapatalk
#24 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 18 January 2017 - 11:09 AM
Do you have this under control before spending money on other stuff? "Car Setup Advice, High Speed Oversteer" Br, Per
#25 Andy_VX
Andy_VX
  • 2,050 posts
  • Interests:Cars, Boats, F1, Cycling, Home Cinema, Music.
Posted 18 January 2017 - 11:34 AM
Won't know for sure until I get it back on track but I've fitted the bigger 1" ARB now so that should certainly help.
From what people have said and my personal feeling I think it's more of a setup issue which can be resolved by experimenting with tyre pressures and damping settings. As I said i'm very pleased with the overall setup, think it just needs fine tuning.
#26 scw02102
scw02102
  • 1,581 posts
Posted 20 January 2017 - 08:10 PM
water/meth injection might be a cheaper way of cooling inlet temps
Has yours been done
not yet, its booked in to be fitted in 3 weeks
