Stage 2 Supercharged Power On Standard-Ish Exhaust ?
38 replies to this topic
#1 bladerunner
bladerunner
  • 57 posts
Posted 18 January 2017 - 01:39 PM
As per title I'm wondering the sort of power to expect on a stage 2 supercharged car running standard exhaust with the pre-cat removed. The reason I ask is the only real option to upgrade the exhaust properly is to go for a tullet but the price for the whole system is eye watering - is it really worth it for stage 2 on a budget ?
#2 smiley
Posted 18 January 2017 - 01:43 PM
It also depends on your rpm cutoff, but i would say 240isch.
#3 Wolfstone
Wolfstone
  • 12,984 posts
Posted 18 January 2017 - 01:50 PM
I think Stage 2 SC boys normally change the NA back box for a turbo one to gain most benefit.
#4 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 18 January 2017 - 01:59 PM
240/250
the same as an "uprated" exhaust.
Makes next to no difference if any at all
#5 smiley
Posted 18 January 2017 - 02:09 PM
You can measure the pressure in your system.
Asuming you will use obdtuner, you can put in a tmap sensor.
With a cheap bluetooth obd dongle you can readout the manofold pressure. Should be around 0.8 bar tops.
If you have more then that, your exhaust will be to restrictive.
Oem NA cat is 400 cells i believe.
Turbo cat is 300 cells.
Sports cat (miltek, larini, tullett) is 200 or 100 cells.
As for durability, it's pretty much unknown if an oen cat can take much SC abuse. Most oem manifolds get cracked at some point. Then it's either a tullett manifold, or a dbilas casted manifold.
Edited by smiley, 18 January 2017 - 02:11 PM.
#6 alexb
alexb
  • 367 posts
Posted 18 January 2017 - 02:46 PM
From experience. I went to stage 2 SC about 80K kilometers ago with completely standard NA exhaust. Got 0.8 bar boost, like Smiley mentions above, and according to OBD Tuner measurement just short of 250 HP. At some stage I put a tubby backbox on. No difference that I could feel. Sounds a bit better, but still crap. I did remove the prekat btw. No issues with the kat. The OEM stuff is not bad at all. But I have to say that the one thing I'm missing from my car is the sound. On the other hand, never had to worry about noise limits and would rather spend the money elsewhere
#7 smiley
Posted 18 January 2017 - 03:08 PM
Was 2016 your second SC year Alex?
How many trackday did the oem cat get now?
#8 Acidpopstar
Acidpopstar
  • 3,555 posts
Posted 18 January 2017 - 03:30 PM
Mine was standard apart from Larini back box. Made 259bhp according to OBD Tuner. Sounded great as well. Now changed to full decat Larini pipe with tubby back box due to the most recent crash I was in :D Wish I still had the standard pipes and cat and Larini back box as I've gained nothing but lost the sound :( Sent from my iPhone using Tapatalk
#9 bladerunner
bladerunner
  • 57 posts
Posted 18 January 2017 - 03:51 PM
Thanks for all the replies. It seems that the standard system (minus the pre-cat) will not restrict power to the point where pistons and rods would have to be upgraded anyway ? I could never justify the cost of a Tullet system so this is good news. At some point I will probably make up a link pipe with a sports cat as I don't think it would be that difficult.
#10 alexb
alexb
  • 367 posts
Posted 18 January 2017 - 03:59 PM
SC'd August 2012. Really had to go back in history to find that. At around 27K. About 110K on the clock now. First track day was in 2014, so say 15-20 track days in total. Doesn't get the same abuse you're giving it. But I have to say that with the exception of the bolts, the OEM stuff is pretty well made. Still trying to convince my wife that the old NA backbox has to go on the wall as a piece of art, but she's resisting.
Must say that I covet (hear that Clarice?) a Tullett manifold. If only there was some kind of window at the back so that you could look at it once installed
#11 smiley
Posted 18 January 2017 - 04:00 PM
Pistons advised upgrade near 270, rods near 300, and liners near 400.
#12 pete-r
pete-r
  • 2,771 posts
Posted 18 January 2017 - 04:49 PM
If your running 265+ on standard internals you've potentially got a time bomb as mentioned. If you want to go faster on a standard engine your only option is via gearing. My odb numbers vary on power runs between 250-260 but I haven't weighed the car accurately etc. I had an OEM system with Larini when I first did the sc and got broadly similar power to now, but I later changed the manifold to a Thorny equal length and the cat to a piper sports model. Torque went up by a useful amount but power didn't really change, that said I do run the OEM rev limit so there may be more left on the table but I'm happy to protect the lump. PS Also I'll second the opinion on the noise on the Larini which has always been superb. Nothing pops and burbles better but with the full system now it's pretty loud to those not used to it.
Edited by pete-r, 18 January 2017 - 04:51 PM.
#13 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 18 January 2017 - 05:28 PM
Same here as Alex: oem manifold and downpipe with precat removed and turbo back box. Key difference is that I swapped from a straight through back box to the turbo one and it also made no difference to the power measured in obd tuner. TBH I didn't like the sound of the straight through exhaust with the supercharger. I prefer the subtle nature of the turbo box despite the MASSIVE weight penalty.
#14 vocky
Posted 18 January 2017 - 05:30 PM
don't you mean ....
rods near 270, pistons 300 and liners near 400
ps: 245-255bhp with a standard exhaust, no precat
#15 smiley
Posted 18 January 2017 - 05:33 PM
don't you mean ....
yes....
#16 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 18 January 2017 - 05:39 PM
Seems I'm doing it backwards to everyone else! Tullett manifold, 2.5" downpipe with 200 cell cat, 2.5" Ubend to de-restricted tubby backbox. ~255bhp on OBD Tuner with standard rev limit.
#17 bladerunner
bladerunner
  • 57 posts
Posted 18 January 2017 - 05:42 PM
So is it the standard pulley size that restricts the power to around 260 bhp ? Or is it also cams and the flow of the head ?
#18 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 18 January 2017 - 05:46 PM
I assume improvements in any area would yield some gains, pulley size would see the biggest gain as that's what most change to go "stage 3" (~300bhp). Not been tempted myself though as it means opening up the engine to do rods & pistons.
Edited by Chris P Duck, 18 January 2017 - 05:49 PM.
#19 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 18 January 2017 - 05:51 PM
Just do the pipo mod on the back box for a bit better tone and a bit better breathing.
Martin S
#20 CHILL Gone DUTCH
Posted 18 January 2017 - 05:53 PM
there is to many variants to put it down to one thing
IAT also play a big affect
