Skoda Octavia Clutch Change, Dual Or Single Mass Flywheel?
Posted 23 January 2017 - 03:29 PM
Posted 23 January 2017 - 03:31 PM
If you're keeping for another 100K, then change. If for another year, why have the hassle, expense and risk?
Posted 23 January 2017 - 03:34 PM
Posted 23 January 2017 - 04:07 PM
The continuing 'it's going to breakdown from the wife' is worth the expense for a little peace!If you're keeping for another 100K, then change. If for another year, why have the hassle, expense and risk?
Posted 23 January 2017 - 04:15 PM
The costs in the end work out to be about the same as the various kits have differing amounts of components, for example the Sachs kit (single mass) does not come with a slave cylinder kit, whereas the LUK (dual mass) comes with a slave cylinder. However, as you say the dual mass is about £50 more expensive. I'll think that I will go for the dual mass as a direct replacement, it's a bit of a bugger after dropping the box to find out that there is a problem, with tolerances etc. Thanks DaveIn general a single mass conversion kit is about the same cost as a new clutch and duel mass. The saving is more in the future when the new clutch needs replacing again. Then comes the question of engine wear relating to fitting a standard flywheel when a duel mass is supposed to be fitted. As you're selling it in about a year, I'd fit a single mass conversion if it was substantially cheaper but if it was about the same price I'd stick to what was designed. If you put your reg in eurocarparts what does it say?
Posted 23 January 2017 - 04:16 PM
Don't want to alarm you but i have heard of these conversions causing crankshafts to fail and gearbox bearings to become noisy. IMO i would stick with the dual mass its done 100k on the original thus far.
I have an account at my local factors, PM me your reg no and i will price it up.
Posted 23 January 2017 - 04:55 PM
standard performance car = leave it dual mass
modified performance car = probably better to fit a single mass
Posted 23 January 2017 - 07:09 PM
Thanks for the offer mate...but just ordered it form my local motor factors, had to crack on with it as got the use of a friend of mines four poster for the weekend.
But very kind of you to offer.
Dave
Posted 23 January 2017 - 07:13 PM
Thanks Vocky, have ordered a dual mass...feel a bit easier replacing like for like, especially with clutches on FWD cars.
