I´m one click away from ordering this, just click the button?
Product Code Stock Price Line Price
Fuel Pump Uprated 340 Stealth In Tank - Astra G/H Zafira A/B Corsa D
High Flow Uprated In Tank 340 Series Stealth Fuel Pump for most petrol turbo applications. This 340 Fuel Pump is a h… 11800 ∞ £82.50 £82.50
Alloy Intake Pipe - VX220 Turbo
All alloy intake/inlet pipe for the Vauxhall VX220 Turbo. The original intake pipe has reportedly experienced problem…
Application: Upgrade Kit for 80mm AFM
Option: Stealth Black Finish
Hose Colour: Red AIPVXT ∞ £119.00 £119.00
High Flow Inlet Manifold and Plenum - Z20LEx
High Flow Inlet Manifold and High Flow Plenum designed for ALL Z20LEx petrol turbo engines The Courtenay Klasen High …
Option 1: With Thermal Gasket and Longer Studs
Option 2: With Inlet Manifold Gasket
Hose Option: VX220 Turbo
Hose Colour: Red
DV Take Off Option: No Dump Valve Take Off Z20HFIMP ∞ £576.54 £576.54
VXR 80mm Air Flow Meter
80mm Bosch/Z20LEH Air Flow Meter As factory fitted on Astra H and Zafira B VXR models. Upgrade Air Flow Meter for … AFMVXR ∞ £120.00 £120.00
