Use your existing wrench or spanner, simply measure 12" from the centre of rotation and hang a 1 Lb weight off it.
Simples (and also precisely accurate if you take into account the wrench/spanner weight).
I find my brass nuts come undone slowly, so I have to wrap wire round them to lock them down sometimes.
I can see why your brass nuts keep coming undone Nev
8nm = 6ft/lbs
Ok, 6 Lb of weight, at least my process was correct!
Theory was good though it should have been half of the spanners weight, I was just wondering if you were using a really long (6ft) spanner!
Have a good weekend
Gaz
Surely the ratio of spanner weight to take into consideration is a function of it's length, not just 1/2.
Separate the spanner and the weight as it is much easier (OK you could weight them as one and find the CofG of the total system but that's pretty complicated compared to separating them for this calc)
If you wish to take the weight of the spanner into consideration you need to know where the CofG of the spanner is in order to calculate the moment.
For most spanners thats about half way along, but if you wish to correct for 22AF at one end and 24AF at the other simply find the Cog G by balancing the spanner and marking the centre.
Don't forget the applied force is between the jaws not at the end of the spanner so to correct for this suspend the weight at the other end of the spanner from the same position between the jaws then your spanner CofG does not need to be corrected.
No need to make any dimention anything in particular just multiply the lengths and weights separately and add them up.
Edited by Spitfire Engineering, 03 February 2017 - 08:20 PM.
