Anyone know the size of the fog lamp opening - seen these on the bay of flea and have combined fog and day running lamps, looks like a good solution to never being seen on the road.
http://www.ebay.co.u...ar=601042538556
Posted 07 February 2017 - 11:59 AM
Posted 07 February 2017 - 12:22 PM
Not sure if the ones you linked are interchangeable. EPC part number for the fog lamp is 9197583
Posted 07 February 2017 - 12:24 PM
Posted 07 February 2017 - 12:30 PM
70mm opening ID confirmed : http://www.vx220.org...-fitting/page-3
Posted 07 February 2017 - 02:42 PM
Posted 07 February 2017 - 02:51 PM
The actual size of the Hole through the bumper is 57mm, although this opens up considerably when you measure the aperture at the flush face of the bumper.
Ah that could be an issue then as these are 64mm
Posted 07 February 2017 - 02:55 PM
They aren't interchangeable but an upgrade with both fog and day running lamps in one lamp.
Posted 07 February 2017 - 03:00 PM
Posted 08 February 2017 - 04:15 PM
Posted 08 February 2017 - 11:35 PM
Originally I used 70mm lamps which was housed on the original fog bracket. This time round I have installed 60mm lamps which actually fit inside the hole. The lamps are both DRL and fogs.
Posted 09 February 2017 - 09:16 AM
Posted 09 February 2017 - 12:24 PM
look fantastic, how are they mounted ?
Posted 18 February 2017 - 09:38 PM
Interested in knowing too !
Got a link to the part ?
Posted 18 February 2017 - 09:50 PM
Posted 18 February 2017 - 10:03 PM
