Guidance For Inexperienced Modifier - Parts Bought For Vxt Upgrade
Posted 09 February 2017 - 03:58 PM
Posted 09 February 2017 - 04:20 PM
At that power a HP fuel pump
Worth dropping the tank anyway to clean it out and inspect for rust.
Posted 09 February 2017 - 05:54 PM
yes you could be able to make the power but I expect the torque to be some what higher
Your biggest issue will be heat
You wont need to uprate the actuator as the VXR turbo comes with one that is adequate
You wont need a remap when you fit the turbo although it will need a map to get the best out of it
You will need a map if you install the injectors so dont fit them until you are at the garage getting ur map. Also if you change the MAF to 80mm at any point it will need a very small map tweak.
You wont need a fuel pump std ones running 300bhp all day long
BOV standard is crap upgrade to the CS Turbo smart
http://www.courtenay.../prod_1232.html
polyflex do both they are soo cheap
Posted 09 February 2017 - 06:23 PM
If you do uprate the actuator this Turbosmart one is nice . So much better built than the Vauxhall one. Avaliable from Courtenay Sport. The Recirc valve is worth doing to as the standard one is flimsy and can break.
I would get an 80mm MAF - the 70mm can fail on a modded VX turbo. 80mmm much more reliable.
Map - well Courtenays a are the most experienced with Vauxhalls but Sizeten (TeamVX) on here has done a lot of good work on a map and it improves driveability as well as power. Matthew Bentley Racing can also map it for you. I have had a Courtenay Stage 4 for years but recently have got a Hybrid Matt Bentley/Sizeten one and it's the business in my opinion.
I had one poly insert done along time ago by Courtenay's and that was the rear. Done the other now too. TBH for the cost you may as well do both.
Edited by P11 COV, 09 February 2017 - 06:25 PM.
Posted 10 February 2017 - 03:49 PM
Posted 10 February 2017 - 03:59 PM
Damn (fnar fnar )Be wary of using oily bush inserts all round.
Posted 10 February 2017 - 10:05 PM
That looks very good - what is actual experience?
Posted 11 February 2017 - 08:57 AM
Posted 11 February 2017 - 08:59 AM
which recirc valve then?
Posted 11 February 2017 - 02:21 PM
Posted 11 February 2017 - 02:31 PM
NGK 6418 , more commonly known as the BKR6EIX which are a good choice
you will not need the 80mm MAF , not without a chargecooler to safely cope with the extra airflow to justify one.
the sensors are same , so its no more reliable
give me a shout if you want a specialist VX map , it can be done at your premises , £500 for any power level and future upgrades for free.
Posted 11 February 2017 - 04:43 PM
Thank you, I'll message you in a couple of monthsNGK 6418 , more commonly known as the BKR6EIX which are a good choice you will not need the 80mm MAF , not without a chargecooler to safely cope with the extra airflow to justify one. the sensors are same , so its no more reliable give me a shout if you want a specialist VX map , it can be done at your premises , £500 for any power level and future upgrades for free.
