Im after a small heat exchanger capable of handling high pressure for a work project, something along the lines of an automotive air conditioning evaporator. Seeing as the Lotus solution must be tiny, it might be just the ticket. Has anyone fettled with them, or has one lying around they want rid of?
Anyone Dabled In Elise/europa Air Con?
Posted 18 February 2017 - 08:26 PM
Posted 18 February 2017 - 08:54 PM
Any used ones will be knackered they tend to kink near the intakes. They arent that expensive to buy new.
Posted 19 February 2017 - 08:36 AM
Just admit it soft cock you want it for the VX.
Posted 19 February 2017 - 09:09 AM
Not as small as you'd think, the heat exchanger overlays the radiator in the same position as a charge cooler. https://www.deroure....&SMO=0&ST=&SC=0
Posted 19 February 2017 - 08:30 PM
@p4cks... ram it
Thats the condenser Tom, I was after the evaporator specifically, as they are generally much smaller as theyre integrated into the HVAC ducting. Thanks for the parts list though, Ive had a dig through and cant see a specific part number for the evaporator. Looks like its part of the whole HVAC unit
