Modded The 2.2 Sc Manifold To Run A Intercooler
Posted 01 March 2017 - 05:35 PM
Having used my sc 2.2 on track I often found I struggled with intake temps and I'd get the CS map cut kick in. Power wasn't massive at 243bhp and I was running the dual pass mod and water wetter but made no difference.
So with the car being raced this year (it's a astra coupe not vx220 sorry) and 40 minute races I decided to mod the intake to accept a intercooler.
So set about chopping it up. The original design is really restrictive looking
Left myself with this
Removed the top lip as well which will aid flow
Before
After
Made a new partition and feed tube (ignore the tube length that got cut down once later once boost pipes were made)
Then second section made
Made myself a new actuator return
http://i693.photobuc...zpskwvjocpf.jpg
http://i693.photobuc...zps4iwgwxnl.jpg
Made up some O rings to seal it
http://i693.photobuc...zpsx56zqbn1.jpg
And fitted
http://i693.photobuc...zpsh52yyglc.jpg
And mock up of pipework for intercooler
http://i693.photobuc...zpsueh3rlst.jpg
I appreciate this isn't a vx220 I'm sure a similar design could be made. The inlet is more compact than standard and a 1/3rd lighter.
I will report back with results/feedback once I've tested the car.
Posted 01 March 2017 - 05:41 PM
nice work
we have also seen good results from using water injection
but will look forward to the results
my next question when your on the CS software how do you monitor the intake temps and how does the ecu know
ie do you use a Tmap
Posted 01 March 2017 - 05:48 PM
Posted 01 March 2017 - 05:52 PM
Water injection is plan b, races being 40 minutes I'd get through a fair bit I imagine and I would need to make it in a sealed box in case of a roll. On the CS software your very limited unlike Dutch software, unless you add an additional probe. Normally you know there high as all of a sudden the map goes rich and you noticeably lose power until it cools enough.nice work we have also seen good results from using water injection but will look forward to the results my next question when your on the CS software how do you monitor the intake temps and how does the ecu know ie do you use a Tmap
Posted 01 March 2017 - 05:56 PM
Are all the pictures showing? Some just have links weirdly.
just external links on some of the pics
Posted 01 March 2017 - 06:03 PM
i get between 20-25 mins out of 2.2 litre tank before it starts kicking in the fail safe from the water level sensor
do you have to have a sealed tank for 100% water (this is what im using )
how does the CS ecu no the intake temps are high if the temp probe is pre TB
are you sure your not getting knock retard
Posted 01 March 2017 - 06:22 PM
Posted 01 March 2017 - 06:26 PM
Tried editing the pic links and they don't change. Could someone fix them somehow? Ah so I'd need a 4.5 to 5 litre tank. I'd have to check the msa blue book but I'm sure all fluids in cabin have to be sealed. On this set up there is no temp sensor pre tb.
whats stopping you not putting it in the cabin ??
Edited by CHILL Gone DUTCH, 01 March 2017 - 06:27 PM.
Posted 01 March 2017 - 06:32 PM
im struggling to see how the ecu is adding fuel when there is no temp sensor in the inlet to tell the ecu the temp
im in no doubt the temps will be high but are you sure this is not just the CS way to add a lot of fuel top end
Posted 01 March 2017 - 07:53 PM
Posted 01 March 2017 - 08:01 PM
Posted 01 March 2017 - 08:02 PM
Posted 01 March 2017 - 09:30 PM
Posted 01 March 2017 - 09:49 PM
Posted 01 March 2017 - 11:18 PM
I'm very curious to your results, but as Joe said it was tried in the US with mixed results...
I'm also with Chill that without a T(MAP) sensor after the SC, your ecu does not know the intake temps and should not be the cause of your issues. However the intake temps will be very high and will make it run richer ands loose power.
I would advise you to install the OBD software and tune the engine properly. And with that you can turn of certain internal safety protections that will hinder you on track.
Posted 02 March 2017 - 12:06 PM
Posted 02 March 2017 - 03:26 PM
Posted 02 March 2017 - 03:30 PM
That's easy obdtuner pro with 100% water injectionI wonder what a mixture of your manifold mods connected to a chargecooler from the vx turbo (given that we all agree the cc is better than the intercooler on a vx ) If I could have a way of supercharging mine to about 245whp (to keep me under 260whp/ton) and be reliable in a 40+ minute race (or longer given the Birkett) then I would consider it.
Posted 02 March 2017 - 03:32 PM
Posted 02 March 2017 - 03:33 PM
