I don't no how strict the rules are nowadays with the owner to weight ratio But maps can be changed at a switch of a switch nowadays giving more rpm or power So do wonder how this is all policed or is it done on face value
spelling corrected
Posted 02 March 2017 - 06:07 PM
spelling corrected
Posted 02 March 2017 - 08:46 PM
I suppose my car will be a test bed this year mark. Our 40 minute races in summer conditions will certainly test it's limits.I wonder what a mixture of your manifold mods connected to a chargecooler from the vx turbo (given that we all agree the cc is better than the intercooler on a vx ) If I could have a way of supercharging mine to about 245whp (to keep me under 260whp/ton) and be reliable in a 40+ minute race (or longer given the Birkett) then I would consider it.
Posted 02 March 2017 - 08:49 PM
Your right you could cheat and have a switchable map but if they suspect your running higher power than you are they can move you up to the next class. We were spot check at Snetterton for weight afterthought race.I don't no how strict the rules are nowadays with the owner to weight ratio But maps can be changed at a switch of a switch nowadays giving more rpm or power So do wonder how this is all policed or is it done on face value spelling corrected
Posted 02 March 2017 - 09:28 PM
So nothing cheap then haha.
its as cheap as 245 bhp gets out of a z22se
Posted 02 March 2017 - 09:31 PM
Posted 03 March 2017 - 03:28 PM
As i cant drive mine on the road a Courtenay map would be easier, if i have to have water injection id probably have to use the dutch software and then have to pay to use a rolling road to set it up. It all keeps creaping up.
Posted 03 March 2017 - 04:33 PM
Posted 03 March 2017 - 08:44 PM
Just borrow someone's reg plates
Ooooh, now you've gone and said it!
You'll have the legal Gestapo after you (Cocopops). I foresee another "mystery" posting disappearance!
Edited by Nev, 03 March 2017 - 08:47 PM.
Posted 03 March 2017 - 09:20 PM
Posted 03 March 2017 - 09:34 PM
The OBD base maps may not be completely optimized for max power on your specific engine, but then run pretty decent out of the box.
Posted 03 March 2017 - 10:03 PM
I'm still running pretty much exactly the same map that Peter sent me. A fuel learn is about all I've really done but it didn't add any power.The OBD base maps may not be completely optimized for max power on your specific engine, but then run pretty decent out of the box.
its as cheap as 245 bhp gets out of a z22seSo nothing cheap then haha.
Posted 03 March 2017 - 10:07 PM
If anything I would say your likely to lose a bit from a fuel learn The real gains are from doing a lot more than just a fuel learnI'm still running pretty much exactly the same map that Peter sent me. A fuel learn is about all I've really done but it didn't add any power.The OBD base maps may not be completely optimized for max power on your specific engine, but then run pretty decent out of the box.
Posted 10 March 2017 - 04:00 PM
Posted 10 March 2017 - 05:01 PM
Great news Adam, it just needed someone with a bit of engineering talent to resolve this bugbear.
Posted 10 March 2017 - 07:50 PM
Posted 11 March 2017 - 09:19 PM
Cheers Nev, there's always a lot of hear say on the Internet so had nothing but a inlet to lose by trying it
Too many keyboard warriors and carbon polishers on here, and not enough have-a-go talent I'm afraid. Considering the number of SC'ed VX220s the community has, it's amazing that nobody really cracked this before.
I expect you might have a few owners PMing you requests to build a few of these if you can show evidence of good IATS.
Edited by Nev, 11 March 2017 - 09:29 PM.
Posted 11 March 2017 - 10:03 PM
Posted 11 March 2017 - 11:42 PM
Nev you're definitely on your period these last couple of days aren't you The problem is space and money. Winstar offered to make a new bigger better intake but the demand wasn't there. There is only a problem when going over 320bhp imo But why spend loads of hours, trial and errors, big headaches when can just fit water injection All the cheap methods like in this thread have been tried and tested and failed unfortunately. As for keyboard warriors..
Well if water injection works and you are happy to stop every 60 mins or whatever to refill then that's great. However a proper long term solution can't be that hard. I've had a look over SC'ed cars and a solution seemed viable to me.
The problem is, these things require a bit of gumption, somewhat lacking on here. You can't just squish all that air and expect it to stay cool. Much as I like SC'ed cars boosting the charge causes real world problems.
As for you inference that I'm just a keyboard warrior, yesterday I was chopping up front wishbones and rewelding them to change the kingpin angle and heavily reduce the castor. Not something I've even heard of anyone on here attempting.
You keep having a dig at me, because I roll my eyes at the development apathy on here. You need to remember it takes people like Adam and myself to push things forward and freely share the results/designs or everyone would still be driving OEM powered cars. You'd do well to remember than next time you buy a "kit part" off the shelf and add it to an NA and then charge someone for it. That "kit part" was developed by someone, somewhere, and in my case I freely share that info (rather than try and make money off people).
Edited by Nev, 11 March 2017 - 11:56 PM.
Posted 11 March 2017 - 11:55 PM
Edited by The Batman, 12 March 2017 - 12:05 AM.
Posted 11 March 2017 - 11:58 PM
My problem is you either have to do it the nev way or you're wrong.
Stopping to fill up a water/methanol reservoir every 50 miles or so is hardly a convenient solution is it? And that is why I think a propper CC'ed system would be much more elegant. I think most people would agree with that, even if it is "Nevs way" as you so disdainfully put it.
As a matter of interest what boost PSI do the stage 2 and stage 3 cars make, and what's the SCR of the Z22SE?
Edited by Nev, 12 March 2017 - 12:10 AM.
