Modded The 2.2 Sc Manifold To Run A Intercooler
#81
Posted 16 March 2017 - 11:34 AM
#82
Posted 16 March 2017 - 11:42 AM
#83
Posted 16 March 2017 - 01:17 PM
#84
Posted 16 March 2017 - 01:38 PM
#85
Posted 16 March 2017 - 02:05 PM
Luke is changing back though.
yes he is but also going 2.4 so nothing comparable
luke has also had to adjust his wheel size to compensate for the power runs etc and always had good power results ???
in the pro version of the software you just select what gearbox you have rather than adjusting wheel size
#86
Posted 20 March 2017 - 07:01 PM
#87
Posted 20 March 2017 - 07:19 PM
#88
Posted 20 March 2017 - 09:03 PM
I love the way you guys have taken our car this far !
Lotus spent years trying to make a good solid track focused car ........
u guys take the bits from gm family and bolt them on an tune away !
Nev is now even cutting up wish bones to try and get more from the car !!!!
You guys really are the bolocks and chaps like me gain a few hp and a little more handling because
of the time you spend drawing fag packet diagrams and scratching you heads in the quest for more power
and handling.
if only there was a VX only series for Turdbo's Na's and SC's then all this effort would be worth it.
Carry on VX'ing guys and make us quicker and stiffer round the bends on our track days or the MaccyD's car park !!
Peace xxxx
#89
Posted 20 March 2017 - 09:19 PM
Just playing devils advocate here You previously had what you believed was inlet temp issues on big pulley ( without knowing inlet temps ) and running rich You then changed to air cooler with some nice work And a smaller pulley Still not sure what you inlet temps are but still running rich no remap As you don't have tmap it's unlikely your lack of power before is down to inlet temp retardation and extra fueling It worry me you were hitting pre ignition and creating knock which cuts ignition and adds fuel And now potentially you have run the car even leaner with smaller pulley compounding the issue And now have high oil usage ??
If a high pressure oil line becomes vented to atmosphere its amazing how much oil you get through
#90
Posted 20 March 2017 - 11:13 PM
#91
Posted 21 March 2017 - 11:25 AM
good look with the remap see if you can get it remapped with a tmap rather than map
and the racing and repairs
look forward to the results
as is new ground using a air cooler rather than water CC
#92
Posted 21 March 2017 - 03:51 PM
As the CS mapping is mostly MAP based and has no intake air temperature measurement, a hot charge (low oxigen content) will be automatically richer than a cool charge (denser oxigen) with the same boost pressure...
(Or differently, a certain amount of cool air charge will show a higher pressure if the temperature rises more, thus leading to a richer fuel mixture from the higher MAP reading.)
Fit an IAT sensor in the manifold and switch to OBD tuner.
#93
Posted 04 May 2017 - 05:41 PM
#94
Posted 04 May 2017 - 05:44 PM
#95
Posted 04 May 2017 - 06:29 PM
41 degrees is perfect. Well done!.
Now we as .org need to develop something like this for our engine:
#96
Posted 04 May 2017 - 06:34 PM
