Flywheel Bolts
Posted 15 March 2017 - 01:01 PM
Posted 15 March 2017 - 05:25 PM
90511423 same bolt is used on z22se and z20let engines, not sure on pitch but will check later
also used on the c20let engine
Edited by vocky, 15 March 2017 - 05:27 PM.
Posted 15 March 2017 - 05:52 PM
Posted 15 March 2017 - 06:09 PM
I have an engine with flywheel bolted on in the garage, can check for you if no one else knows, it's a turbo though (Let ?)
Posted 15 March 2017 - 07:35 PM
just measure it
Posted 15 March 2017 - 08:52 PM
Posted 16 March 2017 - 02:33 PM
Posted 16 March 2017 - 02:57 PM
I used these on my z20let and the pitch is 1.25 according to ARP. http://arp-bolts.com...p?RecordID=1283Found a company that can supply but need someone if possible to confirm it's a 1.25 thread pitch?
Posted 16 March 2017 - 03:01 PM
Flywheel bolts are M10 x 1.25
http://www.ebay.co.uk/itm/262864592192
C20 kit comes with 8 in a pack as it's a 8 bolt flywheel
IIRC the Z20/Z22 comes in a pack of 6, but is the same price
Posted 16 March 2017 - 03:06 PM
Posted 17 March 2017 - 10:09 AM
Cheers guys and that's perfect. Il just buy the 8 kit for z22se from the eBay link and have two spare 😃
Handy, in case 2 bolts snap on your flywheel!
How's the new engine build going? Your car will be totally different once you get that thing in it, fooking mental power potential, enough to rip the paint off your bodywork if you press the pedal!
Edited by Nev, 17 March 2017 - 10:16 AM.
Posted 17 March 2017 - 10:35 AM
or buy 3 x 8 packs , 24 bolts and split them into 4 packs for z22 , keep one set and sell the others on here
Posted 17 March 2017 - 12:56 PM
Yep I've ordered all the bits for the new engine which is 2.4 block, 88mm pistions, Rods, Cams, clutch, flywheel ect 🙈 A lot of money but like you say hopefully it will be quick and a different car 😁Handy, in case 2 bolts snap on your flywheel!Cheers guys and that's perfect. Il just buy the 8 kit for z22se from the eBay link and have two spare 😃
Posted 17 March 2017 - 12:57 PM
If there was 4 other people wanting to do this I would be happy to sort it out.or buy 3 x 8 packs , 24 bolts and split them into 4 packs for z22 , keep one set and sell the others on here
