Following two others users I've talked to who like me have found the Dutch software user hostile (its aimed at tuners not normal people!), I was asked to pass on the simplistic notes I always used when mapping fuel, ignition etc.
Just in case there of any use to anyone else, here they are -
[font="arial, sans-serif;"]Learning fuel maps[/font]
[font="arial, sans-serif;"]NOTE. Never drive for more than 15-20 minutes. Often , even though the EML light has been flashing as if its learning, sometimes the software simply locks up when you click on read ecu to pc, or just sits with an egg timer going and you've wasted all that drive and mileage.[/font]
[font="arial, sans-serif;"]Never also be tempted to cursor along looking at the results of the fuel learning percentages (the green parts) as it processes the measurements, as if you accidentally click the mouse or touch that screen in any way (or even look at it funny), it locks up and you've wasted your time again. I think that in the hundreds of miles and many, many, many fuelling/ignition learning runs I've done, I've on average wasted about 40% of my time and it really does not make you a happy bunny when it happens.[/font]
[font="arial, sans-serif;"](Note, I found that you can shut the laptop doing this option).[/font]
[font="arial, sans-serif;"]Connect laptop.[/font]
[font="arial, sans-serif;"]Open up OBDtuner[/font]
[font="arial, sans-serif;"]Turn ignition on[/font]
[font="arial, sans-serif;"]Select Learn Mode (under main menu), select LEARN MAIN FUEL TABLE (or Ignition_knock)[/font]
[font="arial, sans-serif;"]Go for drive.[/font]
[color=#FF0000;][font="arial, sans-serif;"]On return,[/color][/font][font="arial, sans-serif;"] [color=#FF0000;]DO NOT TURN IGNITION OFF[/color][/font]
[font="arial, sans-serif;"]Select - ECU - Read ECU to PC[/font]
[font="arial, sans-serif;"]click on Measurement [/font]
[font="arial, sans-serif;"]click on Process measurements - OK (Be patient it takes ages)[/font]
[font="arial, sans-serif;"]Save. Give name i.e date_ON_CAR_4.smp (this option of saving comes up at different times, almost randomly)[/font]
[font="arial, sans-serif;"]Select - ECU - Make calibration permanent YES ([color=#FF0000;]IMPORTANT[/color][/font]. [color=#FF0000;]Cars engine will stall when its done (if your just ticking over), which at least makes you aware it really has done something[/color][color=#FF0000;]).[/color]
[font="arial, sans-serif;"]Turn ignition off. Heave a sigh of relief, as for once you haven't just driven a load of miles revving the nuts of your car for another lost session.[/font]
[font="arial, sans-serif;"]Making a log file[/font]
[font="arial, sans-serif;"]Connect laptop and open OBDtuner[/font]
[font="arial, sans-serif;"]Turn on ignition[/font]
[font="arial, sans-serif;"]Under logging, choose Start Logging[/font]
[font="arial, sans-serif;"]OBD tuner will synchronise then start logging. [/font][font="arial, sans-serif;"]Check its working by selecting RPM under logging.[/font]
[color=#FF0000;][font="arial, sans-serif;"]On return, select Stop logging (under logging)[/color][/font]
[font="arial, sans-serif;"]Under logging, [color=#FF0000;]save logged file.[/color][/font]
[font="arial, sans-serif;"](Note, I found that you cannot shut the laptop doing this option).[/font]
