Almost New Vxr Billies
33 replies to this topic
#1 IWOOT
IWOOT
  • 449 posts
Posted 20 March 2017 - 12:54 PM
As you can see these are in near perfect condition:
Spring rates are 47.5N/mm front and 65N/mm rear.
Looking for £600 collected from Aylesbury :)
#2 Mattyboi
Mattyboi
  • 482 posts
Posted 20 March 2017 - 02:34 PM
Will these fit directly on to an NA?
#3 The Batman
Posted 20 March 2017 - 02:36 PM
Yes, they where removed from a Na :)
#4 Mattyboi
Mattyboi
  • 482 posts
Posted 20 March 2017 - 02:49 PM
Goes to do some reading up............................................
#5 r2mlb
r2mlb
  • 772 posts
Posted 20 March 2017 - 05:40 PM
You can collect along with your alloys Thursday if you want... Its a sign :lol:
#6 IWOOT
IWOOT
  • 449 posts
Posted 20 March 2017 - 07:39 PM
:yeahthat: :D
#7 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 20 March 2017 - 10:47 PM
???? Aren't these from a Exige? These are LSS Zolder one's. I've got the same ones.... If they are, they need another front bracket to lower the suspension. The LSS front dampers are 2 cm longer than oem vx ones.... please look link.... http://www.lotus-for...e349d0964132c32 http://www.google.be...SSUK5JHpVgOzidg
Edited by tibby, 20 March 2017 - 10:52 PM.
#8 The Batman
Posted 20 March 2017 - 10:56 PM
Not sure if they are exige ones but both front brackets can come with them :)
#9 IWOOT
IWOOT
  • 449 posts
Posted 20 March 2017 - 11:10 PM
These are definitely VXR ones (although exige could be the same?). The part numbers are 93184426 and 93184427 :)
#10 Sellsey
Sellsey
  • 78 posts
Posted 21 March 2017 - 11:45 AM
Out of interest what springs and rate are on the rears are they 111R or Exige springs?
Would have been interested but have just changed the fronts and only need a rear set but having trouble finding rear springs to fit standard NA billies.
Cheers
#11 Rosssco
Rosssco
  • 4,185 posts
Posted 21 March 2017 - 12:36 PM
Out of interest what springs and rate are on the rears are they 111R or Exige springs?   Would have been interested but have just changed the fronts and only need a rear set but having trouble finding rear springs to fit standard NA billies.    Cheers
  Some info on S2 springs rates further down the page: http://wiki.seloc.or...ension_upgrades
#12 Rosssco
Rosssco
  • 4,185 posts
Posted 21 March 2017 - 12:39 PM
The A-1xxxxxx numbers on the damper and spring should help indicate if they match the Lotus part numbers.
#13 IWOOT
IWOOT
  • 449 posts
Posted 22 March 2017 - 07:52 PM
Sold
#14 The Batman
Posted 22 March 2017 - 08:10 PM
Can you charge him an extra £50 as im going to have to let him on the premises :lol:
#15 Wolfstone
Wolfstone
  • 12,987 posts
Posted 22 March 2017 - 08:58 PM
???? Aren't these from a Exige? These are LSS Zolder one's. I've got the same ones.... If they are, they need another front bracket to lower the suspension. The LSS front dampers are 2 cm longer than oem vx ones.... please look link.... http://www.lotus-for...ge-MK2/64132c32 http://www.google.be...SSUK5JHpVgOzidg
  So after a bit of detective work I found this Post from about three years ago from Mani who is a VXR owner and who has VXR Bilstein suspension:
VXR standard suspension   Front Bilstein Damper F4-BE3-A677-TO / A122C0007H Front zolder springs Eibach 46/03  47.5N/mm   A-122-C-0008   Rear Bilstein Damper F4-BE3-A678-T0 / A122 D0008H Rear zolder springs Eibach 47/03 65N/mm    A-122-D-0006   Mani     This confirms that IWOOT's dampers and springs are confirmed VXR ones but they are also exactly the same dampers and spring rates as the Exige S2 track spec.
#16 IWOOT
IWOOT
  • 449 posts
Posted 22 March 2017 - 09:56 PM
He knocked me down by £50 for the same reason :unsure: :lol:
#17 Wolfstone
Wolfstone
  • 12,987 posts
Posted 22 March 2017 - 10:02 PM
Everyone's a winner then. :lol:
#18 The Batman
Posted 22 March 2017 - 10:03 PM
£50 daily storage fee
#19 Wolfstone
Wolfstone
  • 12,987 posts
Posted 22 March 2017 - 10:21 PM
Lynzi must owe you a packet then. :lol:
#20 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 22 March 2017 - 10:39 PM
VX220 NA = 234 / 268 lbs/in = 42 / 48 N/mm VX220 Turbo = 275 / 315 lbs/in = 49 / 57 N/mm (estimated value) VX220 Spax kit = 250 / 350 lbs/in = 45 / 62 N/mm VX220 NA Nitron kit = 375/450 lbs/in = 68/ 82 N/mm VX220 Turbo Nitron kit = 375/475 lbs/in = 68/ 86 N/mm VXR = 300 / 340 lbs/in = 54/61 N/mm (estimated value) Oehlins = 350 / 400 lbs/in = 63 / 72 N/mm (estimated value) -------------------------------------------------------------------------------------- S1 Standard = 185 / 220 lbs/in = 33 / 39 N/mm S1 LSS = 228 / 285 lbs/in = 41 / 51 N/mm S2 Standard = 228 / 285 lbs/in = 41 / 51 N/mm S2 LSS = 250 / 325 lbs/in = 45 / 58 N/mm Stock S2 Exige rates Stock Exige front: A122C008H 257lb/in Rear: A122D006H 371 lb/in
