Found myself a plastic cam cover from a Vectra C or something. It's 1.8 kg less weight then the alu cam cover so nice and easy you think.
Some folks said it's a direct swap. others said it wasn't.
Now to clear things up here's the deal:
Below the OEM situation. You can clearly see that the rubber ring is sitting on top of it's surrounding.
Now I removed the rubber ring and placed it in the plastic cam cover:
You can see it drops in/below the surrounding.
Now I don't think that last pic is a good way of sealing the plughole. Am I right? How did other people manage this?
When looking for the cam cover gasket set, they mostly turn up with the same partnumber as the Z22SE cam cover gasket set. Confused I say...
Let me hear you!
