Coolant Leak
Posted 29 April 2017 - 04:24 PM
Posted 29 April 2017 - 04:31 PM
Check the bleed nipple of the hose going into the top of the radiator. It's behind the passenger side headlight, and also where the hose attaches to the radiator.
Also check your coolant tank hasn't got a crack in it
Posted 29 April 2017 - 04:35 PM
Posted 29 April 2017 - 05:43 PM
The joint between the core and the where the hose attaches is a known weak point on the OE radiator.
Its starts weeping initially but can eventually just blow apart suddenly, dumping all the coolant in the process.
Clam off job to replace the radiator, so not a cheap fix.
Posted 29 April 2017 - 05:48 PM
The coolant tank is good and everything seems okay in the engine bay. It's definitely something coming from the front. I'll see whether I can access the bleed nipple..... Sent from my iPhone using TapatalkCheck the bleed nipple of the hose going into the top of the radiator. It's behind the passenger side headlight, and also where the hose attaches to the radiator. Also check your coolant tank hasn't got a crack in it
Posted 29 April 2017 - 08:59 PM
I have a spare bleed nipple if you require one.
Posted 29 April 2017 - 10:26 PM
Thanks Ian, I'll be having a look at the bleed nipple tomorrow. Sent from my iPhone using TapatalkI have a spare bleed nipple if you require one.
Posted 30 April 2017 - 08:07 AM
Edited by Deaconp, 30 April 2017 - 08:09 AM.
Posted 30 April 2017 - 08:14 AM
headlight
Posted 30 April 2017 - 12:05 PM
Right, checked the bleed nipple and both connections between the hoses and the radiator and no signs of leakage from any of those.
The coolant trails on the underside are on the driver's side (ie the other side to the bleed nipple). So, I'm thinking either:
1. There is a leak in the hose below the level of the rad. Is this possible? Does it connect somewhere else there?
2. The rad itself is leaking on the underside.
Thoughts gratefully received...!
Edited by Deaconp, 30 April 2017 - 12:07 PM.
Posted 30 April 2017 - 12:34 PM
Posted 30 April 2017 - 01:04 PM
Posted 30 April 2017 - 01:07 PM
Posted 30 April 2017 - 01:10 PM
That was my first thought but fairly sure it's not that. Definitely seems to be coming from underneath the level of the rad. Sent from my iPhone using TapatalkI re entry had a stall leak in the same area, turned out the rad hose clip was pretty loose allowing a small amount of coolant to pass, but only when warm/hot, simply tightening up the clip fixed it. Worth a look.
Posted 30 April 2017 - 02:05 PM
Posted 30 April 2017 - 02:13 PM
If it's pooling into the crash box (shine a light into the grille) it's likely the radiator core. If it's pooling outside of that it's likely the hoses
Posted 30 April 2017 - 02:31 PM
Good point. Just checked. Yes, its coming into the crash box. That would explain why it is appearing from under the clam and streaking across the front undertray.
So, conclusion = radiator core.
New rad time then.
Posted 30 April 2017 - 02:34 PM
Posted 30 April 2017 - 04:07 PM
Posted 30 April 2017 - 08:16 PM
Thanks for the offer but I've already got a date booked with Jonnyboy. I'm going to go with a Coolex rad. Sent from my iPhone using TapatalkIf you're near bucks I can fit a new rad for ya
