Anyone got a Stg.2 SC and a recent static test figure ?
Stg.2 Sc Static Noise ?
Posted 08 May 2017 - 09:22 PM
Posted 08 May 2017 - 09:53 PM
Posted 08 May 2017 - 10:04 PM
Posted 08 May 2017 - 10:11 PM
Posted 09 May 2017 - 04:49 AM
92 for me at Rockingham last year with a Tullet. I was surprised it was that low.... it does sound noisy.
Posted 09 May 2017 - 07:48 AM
All depends on exhaust bud
I'm assuming standard exhaust - also assuming that is even compatible..?
Posted 09 May 2017 - 04:28 PM
Posted 10 May 2017 - 11:59 AM
FYI, dB is usually measured using various filters, this has quite a strong effect on the number, so when you state what dB reading you got you should also state the filter, or else it's pretty meaningless.
Common filters are A, B & C. On my car at idle for example, when I test I get the following readings:
A filter = 92 dB
C filter = 100 dB
Different tracks use different filters. You need to ask what filter they used when you get tested.
Edited by Nev, 10 May 2017 - 12:01 PM.
Posted 11 May 2017 - 08:55 AM
Had mine done at Cadwell yesterday, 2.2, Supercharged, 2.8 pulley Tullett 3" full system.
Read 96DB at 4,500rpm.
I am unsure of the filter though.
Dan
Posted 11 May 2017 - 09:07 PM
How did you get on ? Did you get close to your target timeHad mine done at Cadwell yesterday, 2.2, Supercharged, 2.8 pulley Tullett 3" full system. Read 96DB at 4,500rpm. I am unsure of the filter though. Dan
Posted 11 May 2017 - 10:28 PM
