So after running the VX220 kits here for a few years now I have access to a database of most car models so figured I would offer things up here.
I still have the same limitations as with the VX kits, I can only cut up to 12" in width. For our little cars, this isn't too much of an issue and for most cars it's actually still fine, I just need to be a bit creative with the patterns and we can come up with compromises together that suit. I will use the same ideas I did for the VX, these are cut to allow anyone to fit them, they wont be as precise to edges as professionally fitted kits, I want to give people a bit of wiggle room on making mistakes.
Any kit would pretty much need to be designed with the buyer and I would show you images of the patterns etc before I start cutting. Because of the lengthier process, prices will be a bit more than the VX and due to more material used for bigger cars but things like headlights, bonet lips etc are all pretty similar. the aim will always be to cover the most at risk parts of the car.
You can see feedback in this thread, the guys here have been brilliant at providing feedback both good and bad at showing their experiences of self fitting these kits.
http://www.vx220.org...ection-shields/
So if anyone has any requests, put your car in and ill see what I can do. I expect kits to run around the £150 mark (hopefully cheaper) But again, I can make the quote up quite quickly so you know what to expect
P.S This is still only open to this forum, not being advertised any where else or anything so if you know anyone who wants something and they aren't a member here then I'm happy for you to put them in contact directly if needed.
Edited by pezley, 12 May 2017 - 10:21 AM.
