Breakdown Help - N/a (Ish) Dying At Idle
Posted 14 May 2017 - 02:28 PM
Posted 14 May 2017 - 02:35 PM
Posted 14 May 2017 - 03:45 PM
Posted 14 May 2017 - 04:05 PM
Posted 14 May 2017 - 04:18 PM
might be a stuck (shut) thermostat causing the over-heating ?
Posted 14 May 2017 - 04:51 PM
Posted 14 May 2017 - 04:55 PM
Posted 14 May 2017 - 04:56 PM
Posted 14 May 2017 - 05:12 PM
Posted 14 May 2017 - 05:13 PM
Posted 14 May 2017 - 05:45 PM
Posted 14 May 2017 - 06:39 PM
I would say it's the crank sensor.
Posted 14 May 2017 - 08:06 PM
Posted 14 May 2017 - 08:46 PM
I have heared of return fuel heating up to much causing issues when driving slow from another dutch guy.
Not 100% sure how he fixed it though.
Next run out, touch your return line just for fun.
Posted 14 May 2017 - 08:52 PM
Oh yeah, I forgot you could get ecu's with data logging... Things I dream of.Crank sensor would come up as an error code (I think). Finally home, lots of back roads from the bottom of the a34 but no more breakdowns. Funnily enough, I put more fuel in and haven't had a problem. Makes me wonder if it's a contaminated batch as the first tank was okay until it was half empty. Since diesel or water are higher density, it might not show straight away. Going to pop over and see if they can provide me the fuel CoA
Posted 14 May 2017 - 10:22 PM
That's Dominique on an uprated fuelpunp (and PA tank)...
He gets vapour lock on lower fuel levels when it heats up too much. Quick remedy; fill up tank.
Posted 15 May 2017 - 06:03 AM
hmm, this is the first long, hot day run with an uprated fuel pump. The AA man thought it was vapour lock too. In the end I ended up opening the fuel filler cap each time I stopped, but there wasn't any pressure build up.
Posted 15 May 2017 - 06:08 AM
Posted 15 May 2017 - 06:33 AM
Posted 15 May 2017 - 07:15 AM
Which fuel pump did you go for
DW65c
Advantage (for me at least) is it drops straight into the existing VX fuel canister and pulls less current, which should also mean less fuel heating.
