And you have a Pro Alloy tank? It's not pressure/vacuum build-up, just fuel temperature that creates gas bubbles...
No I don't. I have a standard tank which I assume makes the problem worse (less fuel volume).
So are we saying the heating is purely from the higher volume fuel pump rather than the fuel lines being exposed to engine bay heat? I've fitted steel overbraid hoses and the uprated fuel pump in one go, so the fuel system is completely different to before this point.
I suspect the wider bore return hose with overbraiding will transfer more heat into the fuel vs the OEM installation due to routing, residence time and the fact that they're covered in metal. I can insulate these but if it's the rate of pumping that's the problem I should probably consider a larger tank or derated fuel pump.
