Will 235 Fit
Posted 14 May 2017 - 10:58 PM
Posted 15 May 2017 - 05:36 AM
Will 235 rear tires fit the vx on standard 17" alloys. Thanks
I think even 245 might fit, but each car is different due to clam position. You may get some rubbage, you may need to space the wheel out etc. Also bear in mind that different manufacturers have different carcass shapes, ie one 235 tyre can be quite a lot wider/angular than another.
Eg V70a has a sharp right angle tread to sidewall, R888 wsidewalls buldge a lot, RSR 595 have straight sidewalls and nicey rounded wall to tread.
Edited by Nev, 15 May 2017 - 05:47 AM.
Posted 15 May 2017 - 06:52 AM
lee, haggi and some others have used wide alloys with 235's on and there has been no issues, whether 235's will fit on the alloys i dont know 100%, i think that they will but done take my word for it.
Edited by chris_uk, 15 May 2017 - 06:52 AM.
Posted 15 May 2017 - 08:27 AM
Posted 15 May 2017 - 10:26 AM
Posted 15 May 2017 - 11:03 AM
Posted 15 May 2017 - 11:12 AM
I think some had issues with fitting a 235/40 profile semi-slick tyre on a 7.5" (standard rear wheel width) but a 235/45 works ok IIRC..
Posted 15 May 2017 - 05:59 PM
Thanks for the info.
