been doing some thinking (dangerous i know) and normally ends up costing me money
with a overall reduction in tire and wheel size i am assuming overall weight is also reduced (may not always be the case)
so that is first advantage [color=#0000cd;]unsprung weight [/color]
no real debate there
i accept top speed will be reduced at a given rpm and gear
but now im getting on to acceleration
a smaller wheel in theory reduces the final ratio of the drive chain but does the increase the acceleration or just increases the rate of gear changes
my thinking is the car will cover more ground per gear change at same rpm, but does the weight saving and smaller circumference make up for the bigger wheel
lets assume traction is not a issue
thoughts and opinions on a vx220 setup
