Not Boost!
9 replies to this topic
#1 LordRagnar
LordRagnar
  • 189 posts
Posted 21 May 2017 - 10:00 AM
So for the last couple of days i have noticed i have lost boost entirely it feels like an NA the turbo isn't kicking in at all. The actuator was stuck open but freed that up and still no boost. A couple weeks back I had the boost solenoid changed as i was experiencing temporary boost loss that seemed to have solved the problem but now i've lost it altogether! Took it back to the garage and they say it could be the turbo but before the turbo is condemned any ideas?
#2 LordRagnar
LordRagnar
  • 189 posts
Posted 21 May 2017 - 10:01 AM
Sorry title was meant to say NO BOOST not NOT BOOST Sent from my iPhone using Tapatalk
#3 ayresyy
ayresyy
  • 488 posts
Posted 21 May 2017 - 10:18 AM
Do you have any fault codes?
#4 LordRagnar
LordRagnar
  • 189 posts
Posted 21 May 2017 - 10:24 AM
No no fault codes Sent from my iPhone using Tapatalk
#5 Ormes
Ormes
  • 4,612 posts
Posted 21 May 2017 - 10:39 AM
Split boost pipe/IC?
#6 Nev
Posted 21 May 2017 - 06:26 PM
Have you re-checked that the actuator has not stuck open again?
#7 Duncan VXR
Duncan VXR
  • 5,273 posts
Posted 21 May 2017 - 06:39 PM
Basics to check as pointes to Holding boost, actuator, pipes, etc In limp mode and running actuator boost which can feel lime none depending on spec 😊 DG
#8 VegyBS
VegyBS
  • 183 posts
Posted 21 May 2017 - 08:41 PM
Sorry to highjack, having boost issues too (whooshing noise from 3K revs and no boost from that point) and think it's my something to do with the actuator. How do I actually check if it's working?
Edited by VegyBS, 21 May 2017 - 08:41 PM.
#9 LordRagnar
LordRagnar
  • 189 posts
Posted 22 May 2017 - 06:22 AM
I was also getting a whooshing noise it was quite loud.
#10 ayresyy
ayresyy
  • 488 posts
Posted 22 May 2017 - 06:28 AM
 Whooshing noise could be a split boost pipe, or a split/damaged or even stuck recirc valve.
