Here we have for sale our Courtenay Stage 4 VX220 Turbo.
The spec is as follows;
2004 - 04 plate
MOT until May 2018
75,500k miles
8 Previous Keepers
NOT Insurance write-off
Stage 4 - Courtenay
Team Dynamics Alloys (16/17 setup)
Black V & Windscreen Surround
Pro Alloy Radiator
Pro Alloy Chargecooler
Pro Alloy Actuator
Lightened & Balanced Flywheel
Uprated Clutch
Uprated Suspension Bushes
TTV Underdrive Pulley
ABS Cut-off Switch
VXR Turbo
VXR Injectors
Uprated Exhaust
De-cat pipe
Poly Bushes
Sports Inlet
Gaz Gold 2's
Does have the odd minor scratch here and there, and the usual bolster wear but overall an extremely quick and good-looking car
Nothing needs doing on it, we have recently replaced the header tank, ABS Sensor and wiring, boost hose, gearbox was replaced as it was sticky in first and second gear, new Iridium plugs, cam cover gasket, new battery, oil and filter. Everything works as it should
Also included is a standard sized front plate
We are looking for £13,000
Please note the hardtop is NOT included in the sale
