Exhaust Manifold Replacement
7 replies to this topic
#1 TazN
TazN
  • 2,931 posts
Posted 31 May 2017 - 09:39 AM
Need some of the collective's wisdom.
99% sure my standard manifold is cracked. VX is going in the garage shortly for a few bits and have asked that they fit a replacement manifold. I currently have a 2bular cat (inclusive) back system so need something that is going to fit without being a massive ball ache. Ideally would like to finish the stainless system so not another OEM manifold.
Tullet or Milltek? or other?
Not looking at having a custom fabricated one. Standard n/a so no s/c systems.
#2 james_ly
james_ly
  • 864 posts
Posted 31 May 2017 - 09:47 AM
When I thought mine was cracked the garage found that it was just a broken stud, so they had to drill that out but kept the same manifold. Given the Tullet is big bucks, worth checking...
#3 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 31 May 2017 - 10:30 AM
Borbotta Italie also make tubular exhaust manifolds (4in 1) Dbilas makes a cast manifold.
#4 vocky
Posted 31 May 2017 - 02:10 PM
not many options for the z22se
Tullet 4-1 or Dbilas cast iron manifold
#5 The Batman
Posted 31 May 2017 - 03:08 PM
Can you still buy the dbilas one I had one yeeeeears Ago!
#6 pete-r
pete-r
  • 2,771 posts
Posted 31 May 2017 - 03:32 PM
I lucked into a thorny 4-1 and after a relearn on the dutch it helped the midrange noticeably. The only downer was it also upped the db level as anyone who's seen my car will tell lol. I can't offer anything on the alternative options above but as a rule of thumb a manifold is a really good way to unlock torque.
#7 tibby
tibby
  • 504 posts
  • Interests:POWER
Posted 31 May 2017 - 03:39 PM
Borbotta prices.... manifold 650 euro Full De cat 400 euro racing fia cat 100 650 euro end box 480 euro diameter 64mm
#8 TazN
TazN
  • 2,931 posts
Posted 31 May 2017 - 05:24 PM
Well looks like a tullet it is then.
Eliseparts item has exact same description as tullets website, take it they are the same thing? Is it worth having it wrapped with heat wrapping?
