Action Cameras
9 replies to this topic
#1 siztenboots
  • 26,610 posts
Posted 06 June 2017 - 12:01 PM
looking at the cheaper ones and you now get a lot of more options and 4K UHD etc , but do you really need the image stabilisation , (with the £200 price jump ) ?
also battery life could be a pain , hence some come with 2 to swap
#2 CHILL Gone DUTCH
Posted 06 June 2017 - 12:10 PM
ive got a go pro hero 2
cant fault it
two 8 gb cards last a good day with plenty of footage had it three years now
battery has a battery boost up at lunch in car and its fine
go pro hero 2 for the win
#3 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 06 June 2017 - 12:21 PM
You now get IS in cameras that are £100 so don't need to spend a lot to get that feature.
Not sure how much benefit it would give for a trackday on a smooth surface if you already have a rigid camera mount.
Could see it would help a lot if you were mountain biking!
Battery life not so much an issue. Most cameras let you charge whilst recording. I run a lead to an external battery pack in the side pocket but you could just as easily route one to the cig lighter socket.
The so called 'no-pros' are really very good now, and theres a lot of choice. Worth considering what lens type you like best as you can get now get narrow (90deg) angle lenses. Most action cameras tend to be 130 or even 170 deg which gives you wide vistas but on a trackday it makes everything seem very far away, and flattens height changes. You can fix this on the 4k sensor cameras with a software setting instead tho'.
I doubt you will actually record in 4k much as it'll take forever to upload to youtube!
#4 Ormes
Ormes
  • 4,612 posts
Posted 06 June 2017 - 06:42 PM
I've got a Hero 4 Silver... really very happy with it...
#5 Matt_182
Matt_182
  • 61 posts
Posted 06 June 2017 - 06:49 PM
I use an SJCAM M10 and really can't fault it so far, also has the added bonus as being able to run as a dashcam. I had it linked up to a usb power brick that enabled me to record for aprox 24 hours to catch some pesky neighbours that were damaging the cars!
#6 TazN
TazN
  • 2,931 posts
Posted 07 June 2017 - 06:44 PM
 bought a Drift hd, cant fault the video quality.
#7 siztenboots
  • 26,610 posts
Posted 07 June 2017 - 06:53 PM
went for this 4k , will see how good it is
https://www.amazon.c...0?ie=UTF8&psc=1
#8 Nev
Posted 09 June 2017 - 04:25 PM
I'm glad you didn't post an embarassing video with me squealing in the passenger seat. ;)
#9 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 13 June 2017 - 11:55 AM
Sony sensor, should be good that one  thumbsup
#10 siztenboots
  • 26,610 posts
Posted 13 June 2017 - 12:03 PM
It came with bunch of fittings, for all kinds of sports, but I am to fit it to the harness bar, probably will use cable ties to adapt one of the fittings, plus a san disk 64gb card.
at full hd p60 , around 6 hours shooting , and the cable run to charge off the 12v socket is straight forward.
